Question about Sanyo PLC-XW55 LCD Projector
The warning light on my sanyo PLC-XW55 is on. the projector turns on for a brief second not even long enough for the buld to come on. then it shuts off and the red warning light stays on..
I had that problem too i opened my projector and cleaned all dusts on fans it solved the problem
Posted on Aug 30, 2015
  • 21 Answers
SOURCE: PLC-XW55 KEY LOCK FEATURE
Hi
If you accidentally lock the projector, you need to disconnect the AC power cord. Then HOLD the SELECT button at the same time as reconnecting the AC power cord again.
This should reset the lock out.
Posted on Mar 23, 2008
SOURCE: Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Posted on Jul 07, 2008
SOURCE: I have a Sanyo PLC xu38 projector broken receptical.
you should find a new db15 female connector, and install on to pcb, this required good knowledge of soldering...
Posted on Apr 21, 2009
projdoc
  • 2237 Answers
SOURCE: Describe your WHY IS MY Sanyo PLC-XW55
power supply is bad or lamp door switch is open.
Posted on Nov 09, 2009
SOURCE: How do I get free service manual for Sanyo
SE QUEMO LA ENTRADA DE VGA Y NECITO PLANOS PARA COLOCAR VALORES EXATOS DE RESISTENCIAS E INTEGRADOS
Posted on Feb 09, 2011
Warning light on projector. The projector turns off.
Has it overheated?
Has the lamp expired?
Has a fan stopped working?
Has the ballast unit failed?
Which lamp is flashing?
More details please if it is not one of those common problems.
Thank you
Jan 03, 2011 | Sanyo PLC-XW55 LCD Projector
How do I get free service manual for Sanyo PLC-XW55
Nov 18, 2010 | Sanyo PLC-XW55 LCD Projector
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
I need to replace the VGA cable on my Sanyo projector, model PLC-XW55. I don't know what to get. It's a male-male cable .
Hi hotpinkvalen
If you have a VGA cable, take it to a computer shop or **** Smith and buy a new one.
Just tell them you want a VGA cable. It costs $6 to $10 depending on the shop.
If you don't have one, and if you don't know how it looks like, goto any desktop computer and have a look at the cable which is connected from the computer to the monitor.
It is a male-male cable both ends of the cable have 15 pins.
Hope this will help you
Best of luck
luciana44
http://www.sanyo.com.au/support/instruction-manuals/plc-xw55-instruction-manual
Oct 01, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Hi
Dec 24, 2007 | Sanyo PLC-XU47 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC-XW55 LCD Projector Logo
505 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
