Question about Sharp CD-SW200 CD Shelf System
The 5 cd tray mechanism is broken - Sharp CD-SW200 CD Shelf System
  • 115 Answers
Send back to manufacturer for repair.
Posted on Mar 31, 2011
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Hi Ive got a panasonic home theater scht670, and recently my cd tray broke litteraly broken trying to fix it, and I was wonder if theress a way to bypass the initalization of the cd tray or where can i get...
If you have the broken pieces, try gluing them together with ABS pipe cement (not PVC unless it is also labeled for ABS). If you can't find this, then use metal-filled epoxy (JB-Weld). Unless the tray is in the extended position and the break is outside the the rest of the mechanism, I recommend either manually working the mechanism to get the tray fully extended or disassembling the mechanism to get the tray out. You don't want to risk gluing other parts of the player, and you'll have more control over the necessary clamping of the pieces.
May 17, 2011 | Panasonic Audio Players & Recorders
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
CD tray is not moving in and out easily. Grinding
unplug the unit and open it. the tray is usually controlled by a belt driven by a motor. look and see if the belt is broken. Hopefully yours is not driven by gears.
Oct 24, 2009 | Yamaha CDC-665 CD Player
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
Replace cd drive
There's usually a screw on the bottom of the laptop that holds the CD drive in. Unscrew that, then push the eject button to open the tray, or straighten a paperclip and push it gently into the release mechanism hole in the front of the tray. This will release the tray. Gently pull on the tray and the whole drive should come out. You can probably get a reasonably priced replacement drive from Acer for from Ebay etc.
Oct 03, 2009 | Acer Aspire 3000 Notebook
The tray doesn't open to allow me to put in a CD!
The tray mechanism most likely operates with the use of a belt and pulley system. The belt has either broken or is dislodged from one or more of the pulleys.
Aug 03, 2009 | Philips Audio Players & Recorders
CD tray stuck
while wacking has solved many problems throughout history, i recommend a diffrent method of action here: 1 .check the tray's strap, make sure its elastic enough. if not - replcae. 2. check for broken pieces in mechanism. 3. there may be some object or a accumulation of dust and dirt, stucking the whole thing.
Feb 22, 2006 | Sony (ODSO52XCDRW89) Burner
Sharp CD-SW200 CD Shelf System Logo
51 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
