Question about Vacuums
Wine cooler has error code on bottom half "E4". What are the possible problems?
  • Vacuums Master
  • 17,970 Answers
Sound like a problem with the fan unit; the connectors to the fans get moisture in them and corrode.
Just stripping the wires and hard connecting them, only tool needed is a phillips screwdriver. There are 3 connectors on the side to remove the control panel shelf. Its a pretty simple job.
If this not solve it, need to replace the fan.
Hope helps.
Posted on Mar 31, 2011
How to remove red wine stains from carpet?
Get some Oxyclean spray from the grocery and use that.
Aug 08, 2017 | Vacuums
Futura 250 e4
Error code 04 is that the safety device is activated. I think if it is smoking, it's time to take it to a dealer/repairman/someone who can look at it and tell you what's going on.
Nov 03, 2012 | Singer Futura CE-250
Just moved into a foreclosed house with a GE security system and no manual. We never received the code, which was fine since it wasn't activated. However, when we lost power in a thunderstorm, the...
Is there a phone number on the control panel?
Is there a backup battery that may need to be replaced?
If there is any contact information available, call to get the manual, etc.
Gary
Jul 02, 2011 | Vacuums
When I try to set the time on my electric wolfgang puck pressure cooker, I get an "E4" and a beep. What is the problem?
I actually have one I use all the time at home. We LOVE it but this seems to a common issue.
the problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time.
I have come across this error when I am cooking rice and then trying to pressure cook something else immediately after. I have found that If I release the pressure valve and manually let the steam release, then my chances of getting the getting the E4 errror are less, but it recommends not to do that. :( Another way I have gotten rid of the code was to open the machine. Let it cool off by washing the lid and pulling the pan inster out of the base and let that cool as well. Then I will unplug the machine and basically start all over. The error will go away after some time either way, it's just unfortunate that it can't go from meal to meal when you have several different dishes you need to make. Don't THROW away your machine with an E4 error, just give it time to reset
Apr 07, 2011 | Vacuums
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
How to add freon to dandy wine cooler
Adding Freon to a refrigeration system takes very specialized equipment and years of experience...it would be impossible and irresponsible of me to try to tell you how to do it through a computer...
heatman191
Aug 17, 2010 | Vacuums
The vaccum can not work.
possible solution:
I had the same problem. try plugging in & pulling cord out of rewind a number of times. if motor goes on, you need repair on cord winder. per miele tech-"not common prob.", but repairman said "yes, common prob." good luck.
linda
Mar 25, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Ckeaner drags on carpet
This unit has the outer window, and a half moon window behind it. Check to make sure the 2 screws holding the half moon window are tight and that the plastic hasn't broken. The 2 windows at the bottom cener merge together, they may have come apart. Usually when one or the other window is out of place, it will cause a drag. You may have to replace the half moon window.
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
