Question about Husqvarna Garden
Husqvarna riding mower turns over, yet, won't start. The tank is half full of fuel and it still won't start.
    Brigadier General:
  • 3,911 Answers
Well it is either lack of fuel or spark. Often in the spring mowers will not start as the gas left in them over the winter has turned into a shellac and that has blocked the small fuel passages in the carburetor. There is a fuel additive called Stabil you can and should add to the fuel tank of anything which is going to sit idle a very long time such as a mower, snowblower, RV, etc.
Pull the plugs and spin the crank a few times, see if there is spark and see if the plugs are wet with gas. If no gas is getting through, someone is going to have to remove, disassemble, clean, and reassemble the carb.
Posted on Mar 31, 2011
22 hp in husqvarna mower, will crank and run 2 or 3 seconds and quit, have changed fuel filter and checked for water in gas
If it starts and runs, even for 2 seconds, it's more likely to be a fuel problem than an electrical one...I'd first suspect the carburetor float/valve being gummed up, especially if you've left it sit for the winter with gas in it...if that isn't it, then remove the gas tank and check the tank and lines to the carb for obstructions...
Jan 01, 2015 | Husqvarna Garden
Why does my husqvarna riding lawn mower engine stall when I turn to the left
Probable something in the fuel tank that clogs the fuel line when you turn to the left.
Aug 16, 2014 | Husqvarna Garden
Stiga park lawnmower
Are you certain it is a fuel problem and not electrical? Remove fuel line right before it enters carburetor, turn mower over and see if fuel is pumping out. If not, check for any foreign material in fuel tank where fuel exits the tank to the fuel line. You can do this by blowing pressured air into fuel tank and observe if fuel is coming out of end of fuel line. Check for clogged fuel filter.
Jun 08, 2013 | Garden
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
I have a YTH1848XP Hydrostatic Rider that runs fairly well for about 15 - 20 minutes and then shuts off. Sometimes you can choke it long enough to drive back to garage.
Check the fuel cap, Loosen the cap off and try it, the fuel cap may be plugged or missing pieces. If no air is getting into the tank it will eventually stop the fuel flow to the carburetor and if it sits for awhile you may be able to start it again for another 15 - 20 minutes. It will be worse with a full tank of fuel.
Jun 12, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower won't start
Hi..my name is Keith and some mowers do have a fuel pump..if the fuel tank is lower than the carb...and they are operated by vacuum thats created in the crankcase and they are usually located on the carb...but i would check to see if some trash didnt stop up your fuel line..also..if you have old gas in it..a lawn mower engine doesnt or wont run on it..i hope this has helped..if not..write me back
Jun 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
168 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
