Question about Canon Image Runner 3320I Copier
How do i change the waste toner container on a canon imagerunner 3320i?
  • Canon Expert
  • 287 Answers
Hello tandi,
I can help you. First, lets establish a point of reference which will be you satnding at the copier as if you were about to make a copy. The waste toner bottle is located on the left side,lower rear corner. If you have a stapler/sorter you will need to release it from the copier and slide it away from the copier. Notice the small cover that is @ the lower left corner of the copier. Remove the single screw that holds the cover and then remove the cover. The waste toner bottle is now exposed. It even has a hande so that you may slide the bottel STRAIGHT OUT not up or down. Carefully empty the bottle into a trash bag while keeping in mind that holding it low and pouring it slow will avoid a Hiroshima style mess. Once the bottle is empty, look at the "neck" of the bottle. There are "clear windows" at the top of the neck of the bottle. But right now they are not "clear" since they are covered in toner. That's how the copier determines if the bottle is full or not. It shines a beam through the lenses and as long as the beam is not broken the copier is happy.When enough toner rises in the bottle to break the beam the copier "assumes" the bottle is full. So now that you have emptied the bottle you need to use a Q-tip or such to clean your windows ! :-).Re install everything. Turn the "TRUE" main power switch off, or unplug, and then power back up. Happy copying. Please let "fixya" know if I helped. SPINAL
Posted on Apr 02, 2011
Where is the waste toner container on a canon 7065 copier fax machine
waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
How do I empty the waste toner container?
1- Open The Front door,2- disengage developer unit (DP),3- down the feeder using green handle,4- remove screw of drum unit,5- pull out the drum unit6- empty the waste toner removing with white strip.
Sep 23, 2010 | Canon Image Runner 3320I Copier
Our Canon ImageRunner 400S says to replace the waste toner container. However, I can't find in the manual how to do that.
Waste toner is located in drum unit, look for any cork on drum unit assy, open it, and empty waste toner.
Aug 03, 2010 | Canon imageRUNNER 400S Copier
Where is the waste toner container located and how do I replace it on the Canon 4570 imagerunner copier?
Remove the two screws that hold the front cover on. The waist toner is below the toner container.
May 18, 2010 | Canon imageRUNNER 4570 Copier
How do i replace the waste toner container on a Canon Imagerunner 4570?
The waste toner bottle is hidden behind the front cover of the machine. Just under where you fit the toner cartridge.
If you are competant with a screwdriver, remove this cover and you will find the Waste container. The screws for the cover are hidden behind a rubber bung.
Feb 02, 2010 | Canon imageRUNNER 4570 Copier
I have a Canon ImageRunner C3170U/C3170I
When you open the front cover,there is a transperant bottle with waste toner remove the bottle and remove the waste toner from the bottle.There is aslso a small clear transperant plastic holder that detect the level of the waste toner.Use a no2 star skrewdriver and remove it.Clean it and put it back.And reinstall the waste toner.
Jun 16, 2009 | Canon imageRUNNER C3170I Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon Imagerunner C3100
If you open the front door,the plastic container in front is the waste toner container .Remove that bottle and dump all that toner.Make sure the neck of the container is free from toner inside and outside.And put the container back in it's place.
Mar 29, 2009 | Canon imageRunner C3100 Copier
Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Jan 02, 2009 | Canon imageRUNNER 5020i Copier
Waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
Jan 10, 2008 | Baby Gear
684 people viewed this question
old marine
old marine
