Question about RTO Atwood Water Heater - 6 Gal LP
Nylon drain plug broke off and inside drain hole. how to remove//
  • RTO Master
  • 6,674 Answers
OHHH BOY! Been there, done that many times. I've seen guys try chiseling away at it, ( not recommended) or use a hacksaw blade to cut it down to the threads of tank carefully, then pry and dig near cut to get it to fold up and needle nose pliers to grab it and pull it out in 2 pieces. You will feel the difference between cutting the nylon plug and when you start hitting the aluminum threads of tank, stop there. Best thing I've found, is I have a slightly tapered half round file just narrow enough at end to go into tank and plug about an inch or 2 before it comes up against the broken plug. Then I tap it in good until I feel it starting to bind against metal threads through nylon plug. Then I simply take a pair of pliers or an adjustable wrench, over the file and turn it out. The straight edge of the file jambs in against the nylon plug and walks it out. Good Luck
Posted on Mar 31, 2011
How can I remove a broken plastic drain plug from a hot water tank
You cn either drill it out (make sure the drill is not too big to damage the threads) and then breakit off or drill 3-4 holes in line using a 3mm drill to create a slot so a flat screwdriver can be inserted and used to unscrew it.
Sep 25, 2014 | RTO Atwood Water Heater - 6 Gal LP
How to remove broken off hot water tank drain nipple
You can purchase an ease out tool from Home Depot or Lowe's, It fits inside the broken pipe and when you rotate it counter clockwise it tightens inside the pipe and removes the nipple. (Be sure to check the inside pipe diameter first)
Mar 21, 2013 | Water Heaters
My 6gallons atwwod water heater stop working. the drain plug had 2 wires coming from it. what are they for
"BEWARE OF ELECTRICAL SHOCK HAZARD"!! Wires coming from a drain plug would indicate to me that someone has used a "hot rod" type element in the water heater. They are an aftermarket heating element, that would be plugged in somewhere, (usually inside to a receptacle) that would supply 120 VAC (hydro) to it. BE REAL CAREFUL THAT THOSE WIRES AREN'T LIVE.!! Go in trailer and access rear of water heater if that's where the wires appear to be going and make sure it's not plugged in somewhere. When you removed it, was it similar to a round rod , or just a plug?
Jan 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Sink tap has overflow going directly into the drain and constantly running. This is a reverse osmosis system that is outside warranty.
If you mean the little weep hole on the tap is leaking? If so, then the drain line connected to the sink drain is clogged. Remove this line and see if it's draining free.(have bucket ready) Most likely it will be where it enters your sink drain at that fitting, clogged with sink drain materials.
Jul 17, 2010 | General Electric GE SmartWater Household...
I tried to drain my electric water heater. After about 30 or so gallons drained out of a 50 gallon tank, the drain clogged from the inside. Turning the cold supply back on didn't help, and now my water...
Hi..my name is Keith...you can try to blow air into the drain valve to unclog the debris and see if it will drain..but if it has that much debris i think i would replace the hot water heater..also it has a sacrificial rod inside of it..and if it is melted away then the water will eat at your heaters liner and will eventually eat a hole in it...i hope this has helped
Jun 30, 2009 | RELIANCE ELECTRIC WATER HEATER
Water heater is bubbling with the sound of sediment
You can try to flush the sediment with the water and power on. Just hook a short hose to the drain and shoot it into a clean white bucket (so you can see what comes out). The drains on most water heaters are far too constricted to flush anything but the small particles, so if your problem continues you might consider replacing the factory drain with a short 3/4" dielectric pipe nipple, a 3/4" full port ball valve, a 3/4" m.i.p. x 3/4" garden hose male and a garden hose cap with hose washer. That will give you some serious flushing capability.
If all of these steps won't get rid of your noises take comfort in the fact that the noise may be a nuisance to you, but it is not doing any really bad damage to your heater. I also strongly recommend getting a water softener to prevent this problem from ever happening again.
Mike
Apr 05, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Whirlpool electric water heater wont drain
I had a message from the smart energy controller on my Whirlpool Water Heater that my lower element was failing. I turned off the power and hooked a garden hose to the valve on the bottom and opened the valve with a 1/4 inch screw driver.Nothing happened! I thought the valve was plugged with settling hard water particles. The water heater was in a closet and I couldn't just let it run out onto the floor.
I was out in the garage looking around when I spotted the bicycle pump and found a female jet hose end that could work. Using a small piece of plastic tubing to connect the bicycle pump to the hose end with clamps( I had to remove the bicycle pump hose) and the other end of the hose to the water heater about five pumps and I could hear the gurgling of the air inside the water heater. I disconnected the hose end and put the hose outside to drain. Voila!
Nov 19, 2008 | Water Heaters
RTO Atwood Water Heater - 6 Gal LP Logo
328 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
