I bought a second hand indesit widl1265 but cant work out the setting for the dryer only can you help please?
  • Washing Mach... Master
  • 822 Answers
Http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
try this for a user guide............
cheers
Posted on Mar 31, 2011
I need user manual for indesit wi25
Type your washing machine name into the Google search box and scroll down the list of 'hits'. You'll see your washing machine instruction booklet offered for free as a PDF which you can download in a couple of seconds.
Mar 09, 2013 | Indesit W 123 Front Load Washer
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
Indesit Widl 102 Flashing lights, wont turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Jun 14, 2010 | Indesit Dryers
Indesit WIDL1265 - Noisy on Spin
Hello, this is a symptom of drum bearing wear, and what you need do is to check the wear to see if the inner drum moves up and down relative to the fixed outer drum. It should only moves a minutes amount. If it moves more than a millimeter or two, that means it is probably worn bearings and you will need to replace it.
Thanks
Jun 10, 2010 | Washing Machines
Need manual to download for indesit widl1265s thanks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Although Indesit now own Hotpoint and you can easily get user manuals for there products it seems that Indesit do not supply there user manuals in PDF format, but you could try phoning them and see how you get on.
Consumer service
Indesit Company Service
08448 224 224
Jul 08, 2009 | Washing Machines
Cannot work out how to use dryer only
In your browser bar, type in --- indesit user manual
Then in the drop down list click on manuals- user guides- hanbooks
In the search box type in your model number, and you will be able to down load the instructions.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Washing Machines
Indesit washer dryer 'omega 1200' WDG1295W won't drain!
Sounds like the pump is possibly faulty, or there is a blockage
There should be a removable plastic cover at the bottom front of the m/c, behind this you will see a round plastic cover.
This is the pump filter, unscreit and unblock it if it is full of ****!!!
Hopefully this should solve your problem.
Please leave feedback.
Dec 02, 2008 | Indesit W 123 Front Load Washer
Indesit dryer IS70CS
sounds like the heating element or thermostat has gone in the dryer these parts can be bought from www.indesitservice.co.uk or www.espares.co.uk
Aug 02, 2008 | Zanussi TC180W Electric Portable Dryer
Indesit Washer/ Dryer 1200
A lot of times when people move they find their dryer has suddenly stopped working. Check the voltage at the outlet, make sure it matches the voltage on the i.d. plate on the appliance. I know people who didn't want to fuss with it and bought a new dryer only to find it did the same thing.
Mar 15, 2008 | Dryers
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
