Question about Refrigerators
I have an Eaton-Viking fridge at my cottage in Canada. It freezes some things in the refrigerator and needs a new temperature control. I understand these fridges were made by some other company such as Amana, GE etc. This appliance is quite old but is in good working order except for the temperature comtrol. Is there any possibility that a part to fit this appliance is still available. The model# is R213F, serial #2091241
The temperature issue will not change as you do not have a frost free fridge. With the type you currently have the older it gets the less it works. Think frost free!
Posted on Sep 23, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Eaton Viking fridge model # RF1627 vegetables are freezing despite highest temp setting
sounds like ur thermostat is gone out or u have a duct that runs from the freezer side to the refrigerator side that is stuck open if u have this lil duct take it apart and see if theres a lil door that is stuck open if not ur probably gonna have to replace the thermostat
Mar 01, 2010 | Refrigerators
Eaton viking imperial fridge keeps making ice build upin grate in bottom of freezer how do i fix this problem
the return air ducts are freezing up, unplug unit and use a hairdryer to defrost the entire freezer compartment
this will take a couple of hours to completely thaw the ducts
the ducts are behind the rear panel in the bottom
Nov 02, 2009 | Refrigerators
Fridge is freezing things when temperature guage is on
check damper control or refrigerator door (ajar)
Apr 07, 2009 | Refrigerators
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Freezer not cold enough
Hi yes you do need to keep the room the freezer is in at ahigher temperature probably not below 55 although you will need to experiment to find the minimum you can get away with. This is because modern refrigeration is designed for heated environments and some types are more susceptible than others to this situation.
Hope this will Fixya.
Please remember to rate this solution
Eaton viking fridge model RF1717
hi The limit switch is found only on frost-free refrigerators and freezers. Its function is to keep the defrost heating element from exceeding certain set temperatures. If a refrigerator has lots of frost in the freezer compartment, the problem may be the limit switch. However, other components -- the evaporator fan, the defrost timer, and the defrost heater -- can cause the same problem. Check these for malfunctions, as detailed below. If these parts are in working condition, the problem is most likely in the limit switch. Don't try to fix the limit switch yourself; call a professional service person for replacement.
Oct 07, 2008 | Viking Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
1,428 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
