Question about Datamax Allegro2 Thermal Label Printer
I use a DataMax Allegro 2 thermal printer. My company is upgrading to Windows 7 and the new computer does not have a serial port. I've located drivers(hope they work) but my question is can I use a "USB to Serial". Will the printer function correctly.
  • 124 Answers
"USB" stands for Universal Serial Bus. Adapter should work.
However, whenever you install an adapter, CLEAR unobstructed communication between your PC and the printer MAY be hindered.
Sample website for these adapters - www.usconverters.com/index.php?main_page=index&cPath=67&gclid=CID0zZ6L-acCFUa8Kgod9CkltQ
Another website - www.tigerdirect.com/applications/SearchTools/search.asp?keywords=USB+to+Serial+Adapter
Posted on Mar 31, 2011
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
My problem is i am connecting the intermec pc4 on the laptop windiows 7 and it does not have a pararell cabel in the laptop i am trying to make the mashine recognize the serial and usb port
Read these instructions. You will need to buy a usb printer cable and follow these directions below. Good luck!
We at our laboratory have about 35 Intermec printers and after much trial and error they work well for us. They practically never break. I have also called their tech support and they were very helpful. They advice was FREE. (I promise I do not work for them)
Intermec Install Notes: (from Intermec)
How do I install the USB driver for my EasyCoder PC4 (PC4B or PC4C) printer?
Answer
Tools Required:
1. EasyCoder PC4 (PC4B or PC4C) printer.
2. Microsoft Windows compatible PC. (XP/2000 recommended, Vista NOT supported ( Note from Dole: it works with Windows 7 and probably Vista and Windows 8)
3. USB Cable.
4. Available USB port on your PC.
5. Latest version of the USB drivers (2.0 or better) which can be downloaded from http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4C
Note: There are two parts to installing the USB driver. You will go through the Found New Hardware wizard two times. The first part is installing USB port and the second part is installing the USB to Serial port.
1. Download and unzip the USB drivers to a location on your PC.
2. With the printer turned off plug in one end of the USB cable to USB port on the printer and the other end in to an available USB port on your PC.
3. Turn the printer On.
4. Now you will get prompted with the "Found New Hardware" dialog box. Select "Install from list or specific location" and click Next.
5. Click Browse and select the location where you unzipped the files in step 1 and click OK.
6. Click Next. The USB driver will now install.
7. Now you will get another "Found New Hardware" dialog box for the USB Serial port. Select "Install from list or specific location" and click Next.
8. Click Browse and select the location where you unzipped the files in step #1 and click OK.
9. Click Next. The USB Serial driver will now install.
10. Now reboot your PC. The newly installed port may not show available until you reboot your PC one time.
The USB port is now successfully installed. In Windows the USB port will be assigned to a Com port. To find out what Com port number is assigned to it go to Device Manager and then Select Ports. You will see USB Serial Port (COMx). In addition, when using the Intermec InterDriver Windows print driver. The USB port will be shown as USB00x and the Description will be Virtual printer port for USB.
(You may need to set the printer as the default printer)
Other things to know about these printers: ( not from Intermec )
1) There are 2 types Direct and Thermal transfer. Direct I think heats up the label to get the writing on the ribbon. Thermal transfer uses a one time use ribbon to transfer images to the label.
2) You should use Intermec labels, if you otherwise the labels will probably not print properly
3) How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.
4) Every user will need to set the default label size.
5) If the print is coming out is hard to read do the following. Open the printer then remove the ribbon if there is one and scrape the metal with your fingernail. They give you alcohol and a cotton pad but your fingernail will work fine.
6) Another problem we have sometime is a label falls off and covers a sensor so the labels do not know when to stop. This hardly ever happens but look under the labels and check the sensor.
Feb 18, 2011 | Intermec EasyCoder PC4 Label Printer
Is the zebra S500 printer compatible with windows 7? Urgent!
It is not the printer that need to be compatible, it is the printer driver.
Go to www.seagullscientific.com and download their lattest Zebra drivers, they are Win everything compatible.
Dec 25, 2009 | Zebra Stripe S500 Thermal Label Printer
Datamax Allegro 2
Hi - You can download the manual by clicking the link underlined in blue below:
Datamax Allegro 2
You will need to contact their customer support for the software, the details are here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Epson Printer
Allegro2 Print Too Slow (25 seconds send from Windows XP)
miaharoon: Printing via Windows driver it's too long time because the driver sent a lot data to printer. Also the print speed via serial port it's slow. Inside driver, install Datamax printer fonts and barcode fonts to use it in Windows programs.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 22, 2008 | Datamax Allegro2 Thermal Label Printer
Refuses to print in XP - no error messages
Try going to 'add & remove hardware'. Remove the COM ports. Reboot your computer. Windows should find your hardware and install the COM ports. If not, add the COM ports manually. Leave the printer COM port settings on COM port 1 or COM port 2, whichever you prefer.
Jun 24, 2008 | Datamax Prodigy Plus Thermal Printer
Datamax M-4208 shows ready but does not print
I belive that, PC can detect the Printer and the only problem, the drivers are unabled to route the print queue and that creates a problem.
If your OS is XP/Vista/2000, try the below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall. ((IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : Datamax M 4200)).
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Feb 09, 2008 | Datamax M-4208 Thermal Label Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Datamax Allegro2 Thermal Label Printer Logo
311 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Kevin Brown
Level 1 Expert
Greg Cann
Greg Cann
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
