Question about Refrigerators
Freezer icing up then stops the fan - Refrigerators
  • 132 Answers
There is a problem with the refrigerators auto defrost cycle. The defrost heater may have fallen away from the evaporator coil or the heater has burnt out. You really need to do a full diagnostic on the defrost equipment to spot the real fault
Posted on Apr 01, 2011
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Fan turns off in refrigerator section.
Its issue with defrost timer causing the fan to turn OFF.
Get the timer checked.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ice is collecting on the fan in the freezer causing whirring sound.
Reduce thermostat setting point by point till no ice accumulation on fan.
Oct 01, 2017 | General Electric GSH25JFX Side by Side...
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
The freezer side appears loud rattling noise and noise stop when the freezer door open. It happens couple times per day and last minutes to hour.Please tell me what's going on this
I had the same problem - A fan in the freezer section has ice building up on it and the noise you here is the fan blades hitting the ice. The fan stops when you open the door. I had to empty the freezer, shelves and all; remove the back panel (a pain in the neck) and chip the ice off of the fan housing. I have to do this every few months.
Aug 03, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Freezer has stopped
If it is a frost free side by side fridge/freezer, check evaporator fun in the freezer. While doing that, check is evaporator is full of ice.
if the evaporator is iced up and the fan can spin freely, you have a broken fan. Replace it.
If evaporator and the fan are iced up, you have a broken thermostat. Defrost ice with hot water.
Turn it on, if it starts to cool effectively, replace thermostat.
Oct 11, 2009 | Refrigerators
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
Freezer icing over fan
Check the water spout comeing into ice maker and see if water is leaking out or spilling over
May 24, 2007 | Kenmore 50522 / 50524 Side by Side...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
