Question about Vacuums
The wheel goes around fast but just a hum sound... not the normal sounds. And there is only minimal draw of air. After awhile it just stops.
  • 492 Answers
The upper motor is clogged with debris. To take apart the unit you first remove the screws on the bottom plate where the rollers are. Then remove the fasteners on the upper housing and the handle swivel. Separate the top halves to access the fan motor. Clean the dirt etc. and plug in the vacuum (be careful- shock hazard). The fan will blow out the rest of the dirt. Clean the insides and re-assemble.
Posted on Mar 31, 2011
How to clean/lubricate bearings on Dirt Devil motor?
If you know some one with compressed air blow out all dirt particles best as possible then get a 3 in 1 oil or sewing machine oil drip along the motor shaft and turn by hand you will be able to free the difference once lubricated it should only take a few drops per side . let set for awhile and repeat . then put her together and see if motor speed returns to normal . also check turbine wheel for slipping on shaft.
May 01, 2014 | Dirt Devil Reaction Twin Cyclone Upright...
Vacuum not picking up
Try plugging the hose that goes to brake booster and see if the noise stops couse it seems to me it has a leak..if not spray carb cleaner around the vacume hoses while it is running and where the leak is will couse the idle to go down..
May 10, 2013 | Vacuums
Goes around in a circle and won't go forward was working fine untill my husband cleaned it out with tweesers
sounds like one of the motors on the wheels stop working making it go around in circle and not forward
Feb 16, 2011 | Roomba Vacuums
My miele s571 hoover is humming from a normal sound to a real low hum sound and their is a smell of burning it even through my smoke alarms off what would be wrong or is it worth fixing
It could just be a slipping belt, hair and lint get under the belt and make it stretch the it slips and the spinning drive post heats it up until it starts burning.
Jun 14, 2010 | Miele S318 Bagged Canister Vacuum
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well.
The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
Sep 09, 2009 | Hoover U6630-900 WindTunnel Bagless...
When vacuuming floor the air release opens on its own
Sounds like you have a clog in the throat of the floor head. The air release assures air continues to feed and cool the motor.
Check the floor head for a restriction.
Jan 24, 2009 | Kenmore Quick Clean 30012 Vacuum
Vacuum goes in circles and stops
Blow out the front, dome area with compressed air. All around the little white wheel and the bump sensor in the front of it with air.
Will fix it.
Jul 20, 2008 | iRobot 1100 Dirt Dog Bagless Robotic...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
