Question about Epson Perfection 3170 Flatbed Scanner
When I scan with my Epson 3170 scanner it may not scan at all or after a couple pages the computer gives an error that it has lost connect with scanner. I can hear a faint buzzing in scanner and once I cycle the power it will scan again...for a while.
5 Suggested Answers
SOURCE: Epson 3170 Photo scanner will not work
I don't know specifically what the solution is, but I just downloaded the user manual which has been missing and info from it might help. You might have the manual already, but here is a link to the manual (eighth item down), then go to page 62 and there are a lot of things to look at and consider. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14585
Posted on Mar 20, 2009
SOURCE: 3170 Epson scanner. Never a problem before, but
Turned off scanner. Rebooted computer. Turned on scanner again. Works fine now.
Posted on Mar 23, 2009
ohms
  • 1879 Answers
SOURCE: Epson Perfection 3170 scanner will not turn on.
having the scanner repaired will cost more than a new one.
Posted on Sep 07, 2009
SOURCE: my epson scanner 3170 is flashing a red light and
Disconnect the cable between the scanned lid and the bed. Lift off the lid. Using a small Phillips head screwdriver, remove the two screes that are located where the lid's hinges were. Carefully lift off the top portion of the bed starting at the back. As you approach the front, push it towards the control panel to remove. The front pulley will have either one or both of the plastic flanges will be broken (hopefully just one. In my case, I just used duct tape to hold the pulley down tightly. Power it up to ensure that it's fixed before puttingthe top part of the base back on. If it's not connected to your computer, you should get a flashing green light, or solid green if it's talking to your computer. Put the top part of the bed back on, screw it down and re-attatch the lid.
Posted on Jul 28, 2010
Epson 3170 scanner - have been scanning fine for over 2 years now suddenly says 'unable to write to file' ?! Actually seems to scan OK in preview just will not write file....... any ideas ? Scott
Check to see where it is writing to (which directory) and make sure the directory exists and you do not have duplicate filenames. Check the free space on the drive you are writing to. Run an error check on the drive. If it is a shared folder/directory then check your permissions.
Mar 24, 2011 | Epson Perfection 3170 Flatbed Scanner
Error message on attempt to scan: "Instruction at "0x673328c8" referenced memory at "0x21900668". The memory could not be "read"." need fix.
I must blush to say that I reviewed the error messages more closely and discovered that the solution was with an application, not the scanner. Thanks tremendously for your prompt attention.
Nov 17, 2009 | Epson Perfection 3170 Flatbed Scanner
Software available with Perfection 3170 Scanner?
yes this option is inclussive with your epson scan program, learn to play with the different modes of the scanner ex: professional, home mode etc. usually these modes have these options.
Sep 08, 2009 | Epson Perfection 3170 Flatbed Scanner
Epson Scanner Perfection 3170 can I down load a
Go here
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25021&prodoid=35836301
Aug 31, 2009 | Epson Perfection 3170 Flatbed Scanner
No light when scanner turns on; can bulb be replaced? where to buy?
Unfortunately the bulb on the scanner is not available on retail stores. Epson does not allow end users to take the scanner apart because they might not be able to put the scanner back in together because of the scanner's engineering design.
Please log on to support.epson.com. Click on help me find a service center to the right of the page to search for an epson certified servicer near to your area.
May 11, 2009 | Epson Perfection 3170 Flatbed Scanner
Can not start my scanner
Have you unlock the scan optic? Its usually located at the bottom of the scanner
Apr 27, 2009 | Epson Perfection 3170 Flatbed Scanner
Mar 22, 2009 | Epson Expression 1640XL Pro Flatbed...
Dec 22, 2008 | Epson Expression 1640XL Flatbed Scanner
Epson Perfection 3170 Flatbed Scanner Logo
111 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
