Question about Cell Phones
My LG KP 502 cookie has lost its touchreen calibration. Wherever i press, it actually presses about 1.5cm (roughly 1/2 inches) to the right of the pressing point. I cannot type any 1, 4 or 7 on the virtual keyboard as the presses go to the 2/5/8 keys no matter how far left i press. I tried calibrating my screen but it tells me to press the red dot, i press it and nothing happens. If i press at the aforementioned distance to the left of the dot, it takes it and then tells me to press on a dot in the top-left corner of the screen - I cannot press that. What can i do?
SOURCE: p990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Posted on Sep 17, 2008
  • 34 Answers
SOURCE: sony ericsson M600i touch screen not working,not calibrating
it can be touch pad problem.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: My lg cookies' calibration is completely messed
take a backup of your data and get it formated once it work perfactly fine then
Posted on Jul 07, 2009
SOURCE: cant calibrate screen on i900 omnia.
put a blank file called welcome.not (make using notepad) onto the removable storage card this will bypass the startup screen and mean it does not jam into this look on startup
down load a file phm registry edit... (search on internet) put the cab onto the phone... in stall.. and run
set the sensitivity on this to 20, you can then calibrate the screen... you can try stepping it to 18 16 14 and 10..
this will cure the problem
Posted on Jul 26, 2009
SOURCE: my sony ericsson c510 keypad when typing a text
flas menu
Posted on Jul 24, 2010
My touch screen is not working properly?
Go into "settings", then "touch screen" options and recalibrate.
If the calibration is too far off, you may be able to "walk" it back by touching a point between the crosshairs and where you estimate the phone *thinks* you're touching.
Repeat several times and eventually you should be able to press directly on the crosshairs. You may want to consider using a thin (yet blunt) stylus to press perform the screen calibration for the last time to be sure you're right on the mark.
Jan 09, 2013 | LG KC910 Renoir Cell Phone
Is there anyway i can get my lg phone unlocked to any network free
If you try free unlocking services, You will be definitely ripped off. Because most of the free unlocking services are scam. It is better for you to try any legit paid unlocking service. For example, You can get the unlock code for your LG KP 500 from www.wickedunlock.com/lg-kp500-/rs11wp9/ at low cost.
STEPS FOR UNLOCKING LG KP500
1 - Switch ON your LG KP500 with its ORIGINAL SIM Card,
2 - Enter 2945#*71001#,
3 - Sim unlock mode pop up,
4 - Enter the unlock code and press ok,
5 - The LG KP500 will then reboot and the unlock is complete.
Oct 03, 2012 | LG KP500 Cookie KP 500
My lg cookie wont do what i want at all :/ When i press a screen button it presses the button next to it..so i cant use the left side of the phone at all...how can i fix it ??
You should run touchpad calibration. It's in Settings->Touch Settings->Touchpad calibration. While doing the calibration you should accurately tap at the center of the black cross with a stylus. Hope this helps.
Dec 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Kp 500 cannot sync conflict with camera
try to press the middle button, then select the purple arrow (from up) and select close all button or close just the camera.
Hope this helps!
Apr 18, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Blue convergence is off right will not adjust
Hi. there is a malfunction that has occurred within the convergence chip that is located on the PC board(demod). this is a Hybrid chip that controls the calibrations of the RGB streams. If this chip becomes unstable, it will not allow proper calibrations.
Replacing this failed chip will fix this issue.
The actual sony chip is not available at this time but, there is a compatible chip that will work with your set. i will post a link to the affected part below.
CLICK HERE FOR YOUR REPLACEMENT CHIPS
May 11, 2009 | Sony KP-53V75 53" Rear Projection...
Touch points off
Hi, if you go to avic411.com and search the forum. There are full instructions there to show you how to re-calibrate your touchscreen. I learned from them and did my a while back, but I forgot how. I am sure it still there. You just have to look at the whole forum on the Avic N series. Good luck.
Jan 03, 2009 | Pioneer AVIC-N2 Car DVD Player
Cell Phones Logo
210 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
