Question about Canon PIXMA MP160 All-In-One InkJet Printer
Can't get it to work. It refers to spooler not running?
  • Canon Master
  • 4,338 Answers
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Mar 31, 2011
I am trying to reinstal lexmark software but i got code spooler service is stoped
Here's how to restart the spooler:
  1. Click Start.
  2. Type services.msc in the Start Search box. NOTE: Windows XP users will select Run.
  3. Click services.msc in the Programs list. NOTE: If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  4. Locate and right-click on Print Spooler, and then click Stop from the drop-down menu.
  5. Right-click Print Spooler again, and then click Start from the drop down menu.
You may also refer this link: How to Restart or Reset the Print Spooler in Windows
Apr 04, 2011 | Lexmark X75 All-In-One InkJet Printer
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Hi...i have a Brother MFC290-c all in one setup. My printer was working fine and then one day it stopped. I have tried to reinstall but says Printer spooler failure whatever that means. I went to look at...
Hi. Printer spooler is not running on your computer or there's a need to erstart the printer spooler services. Please refer to steps below.
1. Press Window key + R to open the Run dialog Start and type services.msc and click OK.
2. Double-click the Printer Spooler service, and then change the startup type to Automatic. This sets the Spooler service to start automatically when you restart the computer. Click OK.
3. Restart the computer and try to install the printer again.
If that doesn’t work, the problem could be related to corrupted printer drivers that are installed on the computer. Try uninstalling all printer software from the computer and start from scratch. This may include PDF writer or faxing software as well. Anything listed in the Control Panel under Printers & Faxes I would do away with. If there is any software installed for other printers in Add/Remove Programs I would uninstall it all. Clean out everything possible that might be hanging the Printer Spooler service. Obtain updated software from your printer manufacturers and reinstall only the items you need.
Have a good one!
Jul 10, 2010 | Office Equipment & Supplies
Microsoft said spooler subsystem app not working
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer with your spooler services enable now.
YBC (/\)
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cannot get the printer install it saying the printer spooler is not woking have two more printer said something so brought aother printer i only use one
The spooler is a service running that handles all the printing.
Can you list the exact spooler error?
This page from Microsoft has helped me numerous time with spooler errors, but be sure about the problem as it references editing the registry and this should only be done if necessary
LINK
Dec 08, 2008 | Office Equipment & Supplies
Stooler problem
I believe (and hope!) you're referring to a "spooler" error.
Here's what you need to do:
- click on "Start, Run"
- type "services.msc"
- when the services window pops up, on the right side, scroll down until you see "Print Spooler" then double-click on it
- if the service is not set to "automatic" via the drop-down menu, select that option
- if the services is not started, click "start". If the service has started, click "Stop", wait for a few seconds and then click "Start" to restart the print spooler service.
You might have to reboot after this (a good idea anyway) and you should have no more problems. If you run into continued print spooler problems, you either have spyware/virus damage, or corrupted Windows files (the latter requiring a Windows repair or reinstall)
Hope this helps - remember to rate :)
Scott
Oct 05, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
Problem installing lexmark 2650 on toshiba a 30 satellite
did you add a printer onto the computer control panel
did you down load the printer driver from the manufacturers web page downloads
Jun 03, 2017 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
PRINT SPOOLER NOT RUNNING
When I try to print, a notice appears that the printer spooler serviceing is not working.How can I solve this problem?
Jul 31, 2008 | Lexmark X75 All-In-One InkJet Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
