Question about Maytag MER6772 Gemini Electric Kitchen Range
Top oven not baking correctly. The bottom element get nice and red but the to isn't so bright, making brownies last night oven at 350 and I pull the rack out during baking to put PB chips on them and noticed when I closed the door again that it said temp was still at 350 and the red light stating that it was heating was not on. I pressed the oven button and then it stated that the temp was down to 315 and then the heating light came on. I think its the upper element or possibly a thermostat issue. Any ideas. Thanks
How proficient are you with electrical wiring and electronics?
Just as a test to see if both elements are working, very carefully use a very damp (almost but not quite dripping) to touch the elements when the oven is just turned on. My problem was with the lower heating element, it was not heating. You have to do this before the oven heats because everything will be hot then.
After verifying it was not heating, I unplugged the oven and opened the back panel. I removed the leads from the malfunctioning heating element, attached the alligator leads of my volt meter, plugged the oven back in and turned oven on at 100 deg F; this will establish a potential. I measured voltage and got 26 VAC when I should have had ~240 VAC.
I swapped the orange and tan leads and saw the top element not work and the bottom did. Looking at the wiring diagram, I traced the problem to a relay on the control panel.
At this time I don't know yet if I can find a switch to replace the defective relay or if I need to replace the whole control panel. I sure hope I can replace the relay because the control panel will be ~$300.
Posted on Apr 02, 2011
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
Tip
I have not checked the heating element with a ohm meter yet but the heating...
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good. Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4501853-oven_cord_wiring_oven_3_wire_or_4_wire
on Mar 29, 2011 | Ovens
Why does it take more than 30 minutes to preheat my oven to 400 degrees?
DO YOU HAVE A GAS OR ELECTRIC OVEN???
Gas oven----the bake ignitor is weak and needs repalcing
Electric oven---- does the element glow bright red,if yes swap out for new one---if no need to call for
service and see why voltage to bake element isn't correct
Jul 30, 2011 | GE Ovens
The bottom oven is heating up very slow.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good.Bad elements will often have blisters, bubbles, or even burn in two.
Jan 23, 2011 | Maytag MER6772 Gemini Electric Kitchen...
It takes my electric over a long time I think to
That is a long time, but please give more information on what type of oven you have, and how old it is if the following does not solve your problem. First, Make sure you have not covered the bottom of the oven with any type of barrier to keep the oven clean (aluminum foil or inserts), it blocks the vents. If it is an older convection oven, preheat on bake and set the convection after it has preheated. Check the elements. Lift up the bottom panel and do a visual check of the element. Take out the bottom panel and turn the on oven on somewhere near 450-500 degrees. Visually inspect the element and see if there are bright red areas and dull areas. If the element has red hot areas and dark areas, you need a new element. If the element does not get red at all, you need a new element. Electric ovens usually have an upper and lower element, so you should check both before replacing one. The broiler element should be visible without removing anything, just look at the top of the oven after you set to broil. Lastly, make sure the oven door shuts snugly and that any gasket around the door is in good condition. If you don't know if the door is tight enough, just lean up against it to see if it preheats more quickly. The oven also has a temperature sensor, but from your description, that would not be the case because you did not mention trouble maintaining the temperature.The good news is that elements are usually cheap and easy to replace. Try to find your owners manual, it will tell you what part you need. If not, write down as much info on your oven that you can and take the element with you to the parts store. If this is not helpful, leave comments with more information and I will attempt to solve your problem. thank you for your question.
Nov 18, 2009 | Computers & Internet
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Nov 27, 2008 | Whirlpool RF364 Electric Kitchen Range
Oven was not working. Range and bottom warmer is working, but the oven isn't working.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
if this helps please vote me a fix ya
Jul 15, 2008 | Frigidaire Kitchen Ranges
Oven won't come to temperature
sounds like you may have a bad bake element. can you see hte bottom bake element??? if not you can lift the oven bottom to reveal the "hidden bake element". eitehr way, the elemnet usually looks bad upon closer inspection. theres aburn hole in it or its completly broken. perhapseven a white powder plume from where the element went bad. if thats the case, its an easey enough partot replace yourself. 2 screws and2 wires.POWER MUST BE TURNED OFF FIRST LIVE WIRES AT ALL TIMES TO BACK OF ELEMENT!!!!!!!!!!!!!
Mar 22, 2008 | Maytag MER5775Q Electric Kitchen Range
Whirlpool oven issue
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
106 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
