Question about Radio Communications
No response to radio check
I can hear everbody esle but i cant get out wen i use my mic
    Scholar:
  • 66 Answers
Try this: find another CB radio and tune it into the same channel as the other one and talk on the one you have trouble with and if you hear yourself on the other CB, your radio is fine. But if no one can hear you, you might need to find a better antenna, I'd recommend Shakespear or Moonraker antennas. They're pricey, but worth the money.
However, if you still can't hear your voice on another radio, you may have either a Mic problem or a Transmitter problem. If so, use a different Mic and see if that solves the problem. If not, you may need to get another transmitter or new radio.
Best Regards,
Gavin93
Posted on Aug 07, 2008
I have a PC 78XL CB radio and it is on but cant hear nothing ,volume is turn up
Make sure squelch is turned down enough---if meter shows signal and no audio the internal speaker may be bad (plug one into external jack on rear of the radio).
If the radio transmits and shows it (or someone can hear when you xmit) the problem is in the audio circuit of the radio.
Check internal/external speaker AND SWAP THE MIC as a mic with a broken wire inside or open element as well can cause this.
May 22, 2012 | Uniden Pc-78xl 40-channel Pro Cb Radio W/...
I can hear everyone talk to me but i cant transmit to them,they can hear me key up but no voice to them.i have checked all connections and grounds,still the same.
Mic may have audio wire broken in cord at mic plug wire solder connection.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
notice the numbers on the black plug after you pull it out of the radio.
Sep 12, 2011 | Cobra 29 LTD CB Radio
I have my radio hooked up in my jeep and i can hear other people talk but it seems that they cant hear me talking. Its all hooked up right. i checked to see if there was a tuning thing on it and there...
Turn up "MIC GAIN" also check and see if it keys up full scale 4 watts on output meter. If that doesn't do it change MICS. Go for a power mic by cobra that runs off say a double AA battery. It may be conditions also or your out of range of persons. check Antenna,Swr reads (should be 1.1 to 1.5)on a Radio Shack meter. Try it all.
Jun 11, 2011 | Cobra 19 DX IV CB Radio
When i talk people they can hear me but i cant hear them talk back to me
Turn up your RF gain. If that isn't the issue, then the mic may be damaged. Try a new mic.
Jan 09, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Nokia 5300 mic problem
My mobile has a problem with its speaker. if i close the slide i can hear, but wen i open it i cant hear. Mic is also not working. What is the reason for it...?
Jan 09, 2010 | Nokia 5300 Grey Cellular Phone
No sound
Its, either a broken wire in the mic or the internal speaker blew. Try an external speaker then the mic
Jan 24, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
Wont talk out.
Hey, stubby, Turn you mic gain wide open on the radio. That controls the modulation. Course if the radio has not been tuned that makes a big difference. Also the size of the antenna and how well it's tuned makes a big difference. Mechanic
Apr 28, 2008 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Radio Communications Logo
174 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
