Hi ; I have an Audiovox laser pic-up C.D. it does not want to contect with the C.D's I've tryed playing. The radio and the cassette works just fine. I used Dst Off thinking that might help but to no avail. the model # is C.D1894, listed 77 Ok. there is another# which isEquipment E 58348. this might help you in your anwser tome. Thanks H. Wintony
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on CD's.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all CD discs again.
Good luck.
Posted on Mar 31, 2011
MY CD PLAYER IS NOT PLAYING . NEED HELP
I would assume since it has a cassette player the deck itself is quite old. You can try to buy a CD laser cleaning kit, its essentially a CD with different brushes on them, they were more popular in the 90's and early 00's though so you may have to order them online, or BestBuy sells them for sure. Honestly I feel the kit could be a waste of money, but it may be worth a shot depending on how desperate you are to keep the same radio. If the radio is old, the most likely problem is the laser stopped reading, meaning you need a new radio.Good Luck!
Dec 04, 2016 | Kenwood Car Audio & Video
Help Audiovox Onyx
Its because of the tall buildings and all the power around you breaking the signals.
Apr 23, 2013 | Audiovox Xm Onyx Sirius Xm Satellite Radio...
Yes hi i have a am/fm radio cassette recorder model #ct-992 i have a problem playing the cassettes i open the back and found the problem the little rubber the makes the tapes play broke and i cant find any...
Try entering the make and model number into Search on your Internet browser, along with 'replacement drive belts' and you'll likely get several suppliers if not several pages of suppliers.
Sep 26, 2011 | Audio Players & Recorders
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
Need faceplate for jensen CM715K car radio
try audiovox.com. audiovox now owns jensen.
Jun 05, 2011 | Jensen CM715K CD / Cassette Player
The unit starts to play mp3s then after about 60 seconds it stops and the symbols nod show in the little window after that if you start it it wont play at all. the radio and cassette are fine and the mp3...
with top tray cd players they collect a lot of dust over the laser using an ear bud dipped in metholated spirits or rubbing alcohol rub the lens clean and try the disc again it should work fine
merry christmas
Dec 22, 2010 | Coby MP-CD450 Radio/Cassette/CD Boombox
Error 3 Stereo Honda
Sounds like you need the "radio code". To get the radio code you will need the serial number of the back of the radio.It was given to the original owner with the books. Some times the dealer will put a sticker with a 5 digit number on the walls of the glove box. If that sticker has more then 5 numbers call your local honda dealer because that might ve the serial number.
Jun 08, 2009 | Audiovox ACD95 CD / Cassette Player
Cannot read disc
prob. the laser i have an accurian(radio shack) portable dvd with the same issue. spin motor fires fine but says no disk. just because the laser "lights up" dosent necessarily mean the read section works also. if anyone has a solution to locate a suitable laser please post here as i have a ton of lasers from various drives etc.
Apr 18, 2008 | Audiovox D1708 Portable DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
29 people viewed this question
 Grubhead
Grubhead
