Question about Tricity Bendix AW1000W Front Load Washer
Iv got a Bendix BIW103W, water runs to machine from mains, no blockages, but only trickles into dispencer, doesnt take powder or fab softner into drum, otherwise works ok,
  • john Apr 28, 2016
    your soap dish housing may need cleaning
  • 822 Answers
i would check the water inlet on machine............take the hose off there should be a small filter inside. might be blocked..................
cheers
Posted on Mar 31, 2011
Water in softner compartment
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. Use a pipe cleaner, cotton buds or piece of coiled curtain wire to ensure that the U shaped pipe is clear of obstruction. Pull it back and forward to dislodge any accumulated fabric conditioner. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK then try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spray will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. A good idea is to slightly water down fab con concentrate as it will eventually clog up the dispenser. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Nov 13, 2009 | Kenmore HE2 Plus Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Tricity bendix is just filling up with a tricle of water
thankyou for the offer of help.i did not even know how to get in the machine,and started getting annoyed with it,so,unfortunatly,i am waiting for an engineer to come up,i think it only needs a washer,but,its gonna cost me about £80.a bit expensive,but,desperation calls.plus costing me a days wage,i would be cheaper buying a new one.but thats life,thankyou anyway for taken the time to get back to me.
Jun 22, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Mar 18, 2009 | Tricity Bendix WDR1040W Front Load Washer...
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Mar 03, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
123 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
