Question about NEC Dterm DTP-2DT-1 Phone
I have a dterm series i phone i can see caller id name . how can i see number
4 Suggested Answers
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
  • 149 Answers
SOURCE: I have a 4 line NEC Dterm 80 phone. How do I recall the past
depends on the type pf system. Do you have a coib installed in the system? Is caller id setup or programmed? If there is no mif card in the switch you cannot save caller id info. It only shows up when the phone rings and while on the call. There should be a directory key that you can price to scroll through the numbers if everything above is correct. ldtsnj.com
Posted on Jan 02, 2009
SOURCE: Name Display NEC DTerm Series i
It is changed via MAT or MOC programming. See you PABX Technician.
Posted on Jul 29, 2009
Caller id will not show on the display.
Did you change carriers? A lot of the VoIP carriers like vonage and magic jack will only give you the telephone number on caller id, but not the name.
I have magic jack now and they call that "caller id", but having moved from a carrier that had name attachment i assumed all caller id's had name and phone number both...but not so
Mar 09, 2015 | Panasonic KX-T7453 Corded Phone
How do you Set up number of rings on panasonic Kx tg6621?
Go to your phone menu setup caller id service and check the caller list and assign your ringtone for a particular ID in panasonic kx tg6621
Nec sv8100 IPK DTerm phones Nec phones Inlinecom
Jul 10, 2014 | Panasonic KX-T7730 Corded Phone
How to check caller ID history on the NEC Dterm Series e
Try the NEC company, directly:
http://www.necunifiedsolutions.com/main/support/supcustomersupport.asp
Jan 16, 2013 | NEC Dterm DTP-2DT-1 Phone
On my Uniden Cordless Tru9380 Series phone, how do I use caller ID ? please give deailed instructions as I've had it for 4 days & still cannot figure out how to do it. Help will be greatly...
Caller ID with Call Waiting is available by subscription from your Telephone provider. With this service, you will be able to view incoming caller information while on a call with another user.
This will allow you the ability to select to talk to this user and put your existing party on hold or make the decision to ring them back.
But, you must contact your Telephone provider and subscribe to the service.
Here is the link for the User Guide: http://www.uniden.com/pdf/TRU9380-4om.pdf
Remember, If you subscribe to Caller ID from your phone company, your phone will show you the caller's phone number and name (if available) whenever a call comes in. If you subscribe to both Call Waiting and Caller ID, the phone also shows you the name and the number of any call that comes in while you're on the line.
Jan 15, 2011 | Uniden Cell Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Dec 31, 2008 | NEC DTU 8D-2 Corded Phone
Caller id not working
the directory key is storage for caller id. dtr80 is not the type of system but the type of phone.
The system needs to have other components like a mif card in order to store caller id.
Also if your phone does not ring with incoming outside call than you will not get caller id.
Oct 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Caller ID displays number NOT name
is there a sprint/nextel phones that has a name caller id?
Jun 19, 2008 | Uniden DECT 6.0 Cordless Telephone...
Apr 16, 2008 | NEC Dterm DTP-2DT-1 Phone
Lands Phones Logo
706 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
