Question about AMT Datasouth Datasouth ACCEL 535 Matrix Printer
SETUP FOR AMT ACCELL-535 WINDOWS 7 USB TO PARARELL
On booting it shows Intel AMT Error - Aborting, after a while it then shows 2207 AMT connection failure after which it finally boots to windows. its a hp compaq desktop dc 7700p mini tower convertible bios...
When you boot your computer, you need to hit the key to get you into the bios setup. F10, F2 or Del keys are the usual ones.
Once into the bios, change the boot order to make the CD drive first, and then you will boot right to the CD.
Note, you will also have to hit a key when it starts to boot, it will say, hit a key to boot from CD.
If you miss the key to get into the bios, you have to start over again. Sometimes you have to hit the enter bios key over and over to get in there.
Source : AMT Error
Aug 13, 2012 | HP dc Computers & Internet
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
Amt 6350 setup
your printer is locked up of some functions. to unlock hit alt and form feed then setup twice.
Jan 20, 2012 | AMT Datasouth ACCEL-6350 Matrix Printer
DOWNLOADED THE DRIVES FOR WINDOWS HP AND WHEN I OPEN IT UP TO USE THE SCANNER IT SAYS NOT INTIALIZED. SCANNER NOT FOUND. AND IT IS HOOKED UP WITH PARARELL CORD.
It's due to a port protection in microsoft systems after windows NT, old drivers can't use some hardware connected to some ports (ex: pararell port).
You need to set up your system so drivers can communicate with the hardware ports.
In this case you can use dlportio.dll and follow the next steps:
1) Open the zip file. 2) Copy the file dlportio in one of the following places a) c:\Windows\system32 b) c:\Windows c) The root directory of the affected application.
If it still doesn't work:
3) Reinstall the driver.
If problem still persists you can install some kind of DOS emulator, commonly used to play old abandonware games.
If you need more assistance please leave a comment.
Regards.
Oct 22, 2010 | HP Scanjet 4400c Flatbed Scanner
I have windows 7 home premium. after loading the cd's that came with my old olympus D-535 Zoom. I plugged the camera into a usb port but window's reply is it canot find the camera.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 06, 2010 | Olympus D-535 Zoom / C370 Zoom Digital...
Need a password
Dear i have send some instruction of need a password.
please follow the instructions.
and you receive a password.
Thanks.
1. Download a free demo version of Windows Key (to reset a "Demo12345" password for a trial) or buy an instant download online (to reset an unknown password)
2. Run the downloaded file to install Windows Key. You can install Windows Key on any PC you have access to
3. At the end of the installation process enable the "Run Windows Key" check-box and click the "Finish" button. Windows Key will be launched automatically
4. Create a password reset CD, USB Flash drive or a driver floppy following the instructions below:
Using a Windows Key bootable CD 1. Click the "CD image" link
2. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. The file is usually located in the 'I386' folder of the Windows Setup CD. Click "Next" (Don't have any Windows Setup CD? Request a Windows Key .ISO download)
3. Enter you name and set your own password for the bootable CD (you may set an empty password). Click "Next"
4. WindowsKey.iso file is created
5. Insert a blank CD, specify your burning drive from the list and click "Next"
6. Windows Key password reset CD is ready
What should I do next?
7. Reboot your system with this CD
8. Windows Setup process starts
9. After all the required files are loaded from the bootable CD, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable CD
Continue to step 14*
Using a Windows Key bootable USB Flash Drive 1. Click the "USB Flash Drive" link
2. Connect a blank USB Flash Drive. Click "Next"
3. Insert Windows Setup CD and browse for the TXTSETUP.SIF file. Click "Next" (Don't have any Windows Setup CD? Request { /iso-request.htm } a Windows Key .ISO download)
4. Enter you name and set your own password for the bootable USB Flash Drive (you may set an empty password). Click "Next"
5. Windows Key password reset USB Drive is ready
6. Reboot your system with this USB Drive. To reboot your PC with USB Flash Drive you may need to set the following options for the BIOS Setup Utility: after rebooting your PC please press "Del" or "F2" to run BIOS Setup Utility, go to the "Boot" section and press "F6" to move the "Hard Drive" device up, press "Enter" on the "Hard Drive" option and press "F6" to move the "USB Drive" device up. After all the changes are set please press "F10" to exit and save the settings
7. Windows Setup process starts
8. After all the required files are loaded from the USB Drive, Windows Key starts working. It displays your license info and asks to enter the password that you set for the bootable USB Flash Drive
Using a Windows Key driver floppy 1. Click the "driver floppy" link
2. Insert a blank floppy into the floppy drive and click "Next"
3. Enter you name and set your own password for the driver floppy (you may set an empty password). Click "Next"
4. Windows Key creates three files on the floppy: winkey.sys, winkey.inf and textsetup.oem. The driver floppy is ready What should I do next?
5. Insert Windows Setup CD or bootable floppy and reboot your PC
6. Windows Setup blue screen appears
7. Press "F6" when Windows Setup prompts for additional drivers at the bottom line of the blue screen
8. Windows Setup continues loading required files from the bootable CD or floppies
9. Windows Setup prompts you to press "S" to specify additional drivers. Press "S" and insert the Windows Key driver floppy
10. Press "Enter" to specify the "Windows Key" driver
11. Windows Setup loads the files from the floppy drive
12. Windows Setup continues loading the files from the Setup CD or prompts you to continue with the rest of the bootable floppies
13. After all the required files are loaded from the Setup CD or bootable floppies, Windows Key starts working. It displays your license info and asks to enter the password that you set for the driver floppy
Boot Mode 14. Please enter the password that you have set for the Windows Key bootable media
15. Select the Windows installation to be unlocked
16. Windows Key asks: "Undo Windows Key changes? (Y/N)". Press "N" if you want to reset the password or "Y" if you want to leave the original passwords and cancel the program changes
17. Select the account to reset the password for
18. Windows Key asks: "Reset 'account_name' password? (Y/N)". Press "Y" to reset the password or "N" to leave the original password
19. Windows Key asks: "Reset password for another account? (Y/N)". Press "Y" to reset password for another account or "N" to quit Windows Key
20. Remove the Windows Key bootable media and restart your PC.
Mar 02, 2010 | Computers & Internet
RAID drivers in Windows 7 Ultimate 64bit Setup not detected
Delete the '32bit' folder from your USB drive, and try again to re-install Windows. Hopefully, it will find the '64bit' folder, and will install from that folder.
Mar 01, 2010 | Microsoft Windows 7 Ultimate for PC
MY WIRELESS G MOD F5D9050 DOESNT WORK WHIT WINDOWS 7
It will work with Windows 7.
Did it work before you had Windows 7? If it did, and you recently loaded W7, then make sure you have your profiles setup and setup correctly.
Dec 18, 2009 | Belkin F5D9050 Wireless G Plus MIMO USB...
I have purchased a used Te-2200 cash register. I want to program both the 8 and 5 percent sales tax and also change the name of the business on top. I have been trying all morning with no luck what do I...
To enable edit Company Name
1. Key turn to PGM
2. Press [5] [Subtotal]
3. Press [3][2] [Subtotal]
4. Press [4][2] [CA/AMT TEND]
5. Press [Subtotal]
6. Press [3] [Subtotal]
7. Press [2][1][2][2] [Subtotal]
8. Press [1][7][7][0][7][0][0][0][0][0] [CA/AMT TEND]
9. Press [Subtotal]
Edit ur company name
1. Press [2] [Subtotal]
2. Press [1] [3] [2] [Subtotal]
3. Input Your first line of Company Name (Max 16 Characters)
4. Press [00] [CA/Amt TEND]
5. Press [2] [3] [2] [Subtotal]
6. Input Your second line of Company Name (Max 16 Characters)
7. Press [00] [CA/Amt TEND]
8. Press [3] [3] [2] [Subtotal]
9. Input Your third line of Company Name (Max 16 Characters)
10. Press [00] [CA/Amt TEND]
11. Press [4] [3] [2] [Subtotal]
12. Input Your fourth line of Company Name (Max 16 Characters)
13. Press [00] [CA/Amt TEND]
14. Press [Subtotal]
15. Key turn back to REG1
16 Done
Oct 29, 2009 | Casio Parts Cash Register PC Desktop
138 people viewed this question
Top AMT Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an AMT Office Equipment and Supply Expert? Answer questions, earn points and help others
