Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Everything works except the sprayer. I believe the tube is plugged. How do I get to it?
Nilfisk 150.2 willnot dispence soap when jetting
i have some bad news for you. when using soap not recommended by the manufacture, and you use the machine and use another type of soap or cleaner after you do not run water through the machine to clean the tube and sprayer out of soap the soap drys up and kluges the tubes and the sprayer, and you have to take it to be repaired or buy a new machine. i can test to that the hard way i loaned mine out and it was returned dirty and soap was dried up inside the tube and jets, look at the tube if you see dried up bubbles than the machine needs to be repair and service, service center , sew and vac one place vacuum dealer
Feb 28, 2015 | Nilfisk Vacuums
I have a bissell pro heat2x turbo. my problem is that the sprayer underneath is not working, also it sounds as if there is air coming from somewhere.
Sounds like there is a leak or crack somewhere in your tank.
Check the tank and tubes for damage or clogs. You may have to replace your tank.
Proheat 2X Shampooer Shampooer Parts
800-775-6586
GoodVac com
Feb 22, 2015 | Bissell Vacuums
Hoover spot scrubber sprayer not working well.
you can replace both tubes if it helps or you can check for blockages and check the pump off the video below
http://www.youtube.com/watch?feature=player_embedded&v=1sSVIu6arbY
Oct 31, 2012 | Tti Vacuums
Everything seems to be working fine except it has no suction. I changed the bag and filter, but still nothing.
Probaly a clogged suction tube, unplug the vacuum first then tilt the vacuum upside down and see if you can see a clog .On the back side of the brush it will be kinda funnel shaped and that leads to your suction tube . That is the most common place for a clog.
Rate my answer with the thumbs..........Thanks
Dec 03, 2010 | Kenmore 35912 / 35913 Progressive Upright...
My hoover steam cleaner will not put down the soap solution? Any suggestions!
The line may be clogged.
If you look in the tank see anything blocking?
No? Okay moving on. You may need to remove a cover or covers.
Find the lower end of the line / tube.
Carefully remove the line.
Now with safety glasses on take a can of air, and blow the the line & sprayer out. Replace all parts you removed.
In the tub, shower or outside. Add vinegar & distilled water to tank let set for 1 hour then see if it will work. Let the water go down the drain or outside. If this don't work you may have a bad sprayer switch.
Please let us know.
May 18, 2010 | Hoover F5842-9RM Steam Vacuum
Water doesn't circulate from the tank to the rug
Have you checked for the sprayer nozzles under the clear vacuum housing are not plugged with some foreign debris, carpet fibre buildup etc. Place the unit on bare floor and engage/turn on the motor/pump and pull the trigger/switch? No water? Check also that the hose/attachment wands have water or not? If they are operating then the nozzles to the carpet off the main unit may need to be cleared by using a pin (Safely) se if there is no foreign debris in sprayer nozzle. I have seen soap solution gone crystalized and the minute pieces clog up the on board prefilter and yet somehow clogs the nozzles as well. you may have to take the top of the unit off (approx. 6 screws) and see if there is water flow or maybe a kink in water /sprayer/nozzle line. Good luck
Apr 30, 2010 | Bissell 1699 ProHeat Clear View Upright...
I am having problem with the sprayer to work.. It doesn't seem clugged any suggestions
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 22, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell 25A3 ProHeat wont spray water
I had two problems. No water was coming out of the main unit (it was working fine via the powerbrush) and the flow indicator wasn't spinning. Because I'm out of warranty, I did two things (after trying all the options that were posted).
1. Removed the top of the main unit. There are 4 screws on the top back lid. Once you remove those, lift the back up towards the front. The front is snapped under the bottom casing. It should come up with a little pressure, but don't force it. With the top lid removed, I had to clean several of the rubber hosing by removing them and running under warm water. I actually used a long wooden skewer to scrape the grime in the tube. Make sure you do one tube at a time and replace in as it was before moving to the next one. While you are at it, make sure the 2 sprayers on the front are clean as well. They are either orange or yellow and rubber tubes also feed into the sprayers. After I finished, I replaced the lid. It it still wasn't working, so I tried step 2.
2. Remove the hose assembly from the main handle. 2 screws and 2 bolds (don't lose the nuts from the back). Once the hose assembly has been removed, then lift off the top part of the handle. Once the top is off you should be able to open the front lower part of the handle exposing the additional electrical and more rubber tubbing. In the middle is rectangular looking object. That is the water heater. If you just ran the vacuum, do NOT touch this as it will be hot. Wait for it to cool. check the connections of the rubber tubing and make sure they are clean. In my case the tube going in to the heater was all blocked up with cleaner solution. Once I cleaned that up an reassembled in reverse order, the unit worked fine.
Hope that helps you.
Apr 22, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Kirby foam sprayer attachment wont work
The trigger on the suds gun needs to be turned (to the left, I believe) to open up the sprayer. Also, make sure that the straw is firmly inserted into the hole in the bottom of the lid part. Hope this helps,
Marci
Jun 09, 2009 | Kirby G6 Bagged Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
