Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Have a jam error. paper folds in front of print roll
  • Xerox Master
  • 4,338 Answers
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Posted on Mar 31, 2011
How do i feed the paper of the casio fr 2500 printing calculator
Hello Michel Dekock,
Could not find your FR2500 (but close)...
Has worked every time for me...
Mount the paper roll on the wire bracket... feeding
over the top of the ROLL (TOWARD THE MACHINE).
With the keyboard FACING away from yourself
Fold the FRONT EDGE of the PAPER on to the
side to form a chisel point... and insert the point
(folded side up) in the rear roller slot (paper feed)...
As shown on FR2650
http://www.ebay.com/itm/Casio-FR2650TM-Printing-Calculator-FR2650TM-/122298781152?hash=item1c79934de0:g:bwEAAOSw44BYbWjv
With the PRINT feature turned on the roll should be
advancing while holding down the TOTAL key...
Hold the key until the edge of the paper roll emerges from the machine.
Hope that helps.
(now you only have to freshen up the ink).
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
Mar 27, 2017 | Casio Office Equipment & Supplies
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
On the front of the printer Lexmark E120 a picture of paper with a corner folded down. Printer wont print and there is no paper jam, what does that one mean?
The picture of paper with a corner folded down is Load/Remove paper. Can you describe the status lights of the printer? The light sequence will indicate specific error and status of the printer.
For further assistance, please contact Lexmark Technical Support.
Jul 18, 2011 | Lexmark E120n Laser Printer
I installed a new black ink cartgage and printed a alignment page. After alignment was finished I tried to print an envelope through microwsoft word and received a jam message. I have no paper missing on...
in the back of the printer, there is a plastic door try to dismount check if there is some thing triggers the "jam " error put it again and check, if not, try by your hand to put the head on far left side, some jam errors are from lost head position , then check the rolling rod it has plastic finger looks like half-round, if this finger is jammed and it's tip is not smooth with paper flow it will trigger paper jam
this plastic finger might jammed before and strongly removed the jammed paper which might changed it's curvature hopefully it work
Dec 07, 2010 | HP Officejet J5780 All-In-One InkJet...
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Paper jam
take out all the paper from the loading tray, and press down on the inside of the tray 4 or 5 times, and put a sheet back in. There seems to be a physical irregularity with all 2300DL printers that causes this problem
Sep 19, 2008 | Konica Minolta magicolor 2300DL Laser...
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
51 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
