How can I get rid of line interference? - Computers & Internet
  • JDTec
    JDTec Mar 31, 2011
    on what equipment?
  • 27,725 Answers
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Mar 31, 2011
Why do I have rolling horizontal lines on my hitachi big screen t.v.?
Need the model number of the Hitachi which should be listed n the rear cover. I should be able to assist but will need the Model Number to determine which chassis design you have.
Apr 02, 2013 | Hitachi Televison & Video
I have black and white lines running down the screen after I connected it to internet. How do I get rid?
Could be a lose cable, Check the cables connecting to the monitor (screen) and the to PC.
Also, made sure your phone or any other electronic device(s) aren't in close proximity to the screen. They sometimes cause interference.
Jan 07, 2013 | ASUS Computers & Internet
What exactly does the anl nb/anl button do on my cobra 29 wx nw st
ANL stands for "Automatic Noise Limiter" and NB stands for "Noise Blanker".
The ANL gets rid of a lot of interference noise caused by mechanical noise from motors and other electronic components in a car.
It also gets rid of noise from other sources of interference.
The NB is for extreme cases of noise, but can slightly lessen your receive sensitivity.
Basically both functions help decrease interference noise.
Nov 24, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I get static so bad that I can't squelch it down enough to get rid of the noise. Traveling out on the highway it usually works ok. But when I enter a town the static gets badusually around power lines. How...
You could install a filter in the line between the antenna and the transciever. I reccommend a high-pass or band-pass filter set for the 27 MHz band to remove any interference at different frequencies. Also, some older TVs can cause interference to CB radios if they are close. If this doesn't work, the radio may be poorly sheilded or your area may have implemented the broadband power line initiative (BPL). This produces a strong buzz of noise that obliterates all weak to moderate radio signals between 2 and 80 MHz (CB being at 27 MHz).
May 21, 2010 | Cobra 19 DX IV CB Radio
How do i get rid of the static in my model CKS2235B radio? The original literature which i no longer have indicated that the power cord is an antena. There is no one position that works with that approach....
You will have to place the radio away from any noise sources. Like television,lamps, fans, other stereo equipment,refrigerators. These all cause noise on the a/c line current. This is the source of noise. You can try using a/c line filter/surge protectors to stop the line noise interference. Plug the radio into this and place it near a window so it can easily find the signal source.You can also look on line for more information on how to limit noise interference on a/c line connections. I hope this information help you with your problem.
Apr 17, 2009 | Emerson Smartset Clock Radio
Blue line - screen
Your control board and address circuits need to be examined. This could be a component problem or a simple fix such as installing a new ribbon cable from the control board too the address circuits on the LCD panel itself. To do this would require a technician, but before this issue gets worse you should have it repaired.....check to see if its under warranty.
Some people have tapped the back of their tv and got rid of vertical line interference. But , I wouldn't suggest that method.......
Feb 26, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
