Question about Siemens Dishwashers
My 10 year old Siemens dishwasher is no longer circulating water. I have already looked for obvious blockages. Where to go now?
  • 822 Answers
Check the pump motor...........
cheers
Posted on Mar 31, 2011
Burning Smell inside siemens dishwasher
Most likely the smell is coming from a motor that is having a hard time turning, so it's overheating. Don't run it or it might catch fire!
Apr 22, 2017 | Siemens 24 in. SE64A630GB Built-In...
Water is not draining from Bosch Dishwasher 10 yrs old
Give this video a try. There are lots of places where gunk can build up and this video shows you how to do it on a Bosch dishwasher.
Dec 04, 2017 | Bosch 24 in. SGS43C12 Classixx...
My Siemens Hydrosensor dishwasher seems to go through the entire cycle but at the end mainly the top rack of dishes, sometimes the bottom rack is completely covered with a film of junk. It ends the...
It is obvious the drain or pump out is not working. There is a blockage in the outlet. Check the drain under the sink nby removing the hose and making sure the hole is not blocked. The pump in the dishwasher may be blocked. fixing this may not be within your field of expertise and a technician may be needed. Good luck
Jul 31, 2010 | Siemens 24 in. SE53200 Built-In Dishwasher
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
Jun 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Siemens Dishwasher - no water coming in
It could be 1 of 2 things, first (most likely) is that by turning it upside down some dirt has gotten into the pressure switch, that's a disc shaped device with 1 or 2 small tubes and some wires attached. in this case you have to find the switch (usually high up on the front or back) remove the longer tube and blow down it to clear the blockage.
Or it could be your inlet valve is not working, this needs ac mains on it, for a solenoid that opens the valve, again you may need to remove it & see if the coil isn't burned out, either a multimeter or just put mains on the 2 wires & hear if it clcks open. Inlet valves can sometimes get blocked, so they don't get the pressure needed to open, i also had this problem in a high-rise flat where the water pressure was too low!...hope this helps...
Mar 24, 2017 | Siemens Dishwashers
My Siemens SE64A630GB does not drain.
Could be the pump or controller has failed if no blockages.
Nov 27, 2007 | Siemens 24 in. SE64A630GB Built-In...
Dishwashers Logo
255 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
