Question about Frigidaire Dishwashers
I have grit on my dishes especially my glasses. What should I try?
  • 5,081 Answers
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Posted on Mar 31, 2011
I use siemens dishwasherand recently noticed some grit like substance left on my dishes etc after every wash
There should be a screen under the spray bar. Make sure that is clean. So "grit" is not recirculated in the wash cycle. Is "grit" showing up in your house water elsewhere? Check with clear water glass. Also consider testing with a competitive wash compound to see if there is any difference. A sample or from your friends.
Apr 14, 2015 | Siemens Dishwashers
Grit in clean glasses and on dishes
Mary do you have a water softener? If so, only use 1 tablespoon of dry dishwashing detergent per wash. Don't use tablets or liquid soaps. Too much soap will wear down the items you wash, leave streaks and pock your dishes. That might be what the sandy grit is. Also, to get rid of the grit inside of your washer you can buy a special dishwasher cleaner at almost any hardware store. Always try to use a rinse-aid. Make sure your drain filters are clean. Hope this helps. Jewels
Mar 15, 2013 | Dishwashers
Leaves fine grit inside glasses, cups, etc. Dirtier dishes than before washing.
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The "fine grit" is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 28, 2011 | Bosch Evolution 300 SHE43M05UC Stainless...
There always seems to be a sandy grit substance on my dishes especially glasses, what do you suggest? thank you
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Jan 26, 2011 | Hotpoint 24 in. HDA3740G Stainless Steel...
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
Seems that food particles are "regurgitating" back up into the dishwasher and leaving grit on dishes - primarily glasses and silverware. Have had dishwasher probably 3 years -maybe less. Don't know what...
That "grit" you are referring to is actually coming from your detergent. It is part of the cleaning enzymes that assist in scrubbing your dishes. If it is ending up on your dishes, you are on the right track. You need to check the main wash pump and clean as necessary to ensure there are no obstructions on the sump area. The drain pump inlet is also in this area and should additionally be checked for debris. If you could please post back with a model number, I may be able to give you further guidance on how to disassemble the spray arm so you can access this area.
Jan 04, 2010 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Grit like residue after cycle finishes.
I had the same problem and it was fixed by switching dishwasher soap. We always used the same liquid soap for years and when this problem came out of the blue (about 8 months ago) I switched to Cascade action pacs with Dawn. It did the trick! No more residue since then. We now are having a problem with the dishwasher not draining (our unit is 8 years old), but the grit issue has been handled!
Aug 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Open Questions:
Dishwashers Logo
146 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
