Question about Sharp Office Equipment & Supplies
Sharp CS 2187 Cannot set the decimal point to show currency
  • 91 Answers
SOURCE: I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this Sharp.com page which shows the users manual. The manual shows examples.
Posted on Mar 19, 2008
  • 125 Answers
SOURCE: SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
Posted on May 05, 2008
SOURCE: display shows comma in place of decimal point?
To change the ´comma´, make sure the calculator is switched to off, press (.) key and maintain, switch the calculator ON. This operation changes dot to comma and vice-versa.
Posted on Aug 11, 2008
  • 3 Answers
SOURCE: setting it to 2 decimal points
You have to make sure that the third set of buttons wit the K*A is set to A and the 5th set of buttons is on the 2.
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: 12C Calculator
Press "f" then 2. The number you press after "f" sets the number of digits to the right of the decimel point.
Posted on Mar 16, 2009
How to change decimal point
If you want all entries and answers to have two numbers after the decimal, you should have a lever or slide that shows F,6,3,2,1,0. Some also show Add. Set the lever on the 2 or add. F means floating decimal. the others indicate how many numbers after the decimal.
Oct 30, 2014 | Sharp EL-1701C Calculator
Decimal point
Most models require currency decimal to be set during a full memory clear so you may lose all programming. If you need a programming manual, one of the users has most of them here:
http://the-checkout-tech.com/
Sep 04, 2013 | Casio Parts Cash Register PC Desktop
I just bought a Sharp Compet CS-2187 at a garage sale, but I don't understand all the switches at the top (e.g., DU CF/P.D, etc. I also am not sure how to set it so the decimal is always in place for...
Pam: I also have that calc. I also need instn manual for same reason(s). Works fine for 30 yrs old.
Did U get the User Manua?
Don deBruyn
daphrogue@bellsouth.net
May 31, 2011 | Sharp Office Equipment & Supplies
Sharp EL- M332 caluclator- have a 'O' along top line- can't seem to get rid of it- must have accidentally selected something. It is not showing any decimals.
Hold (C.CE) then whilst holding it press (M+) for approximately a second and it will move one place along in the three settings (F, 2 and 0) F shows full decimals, 2 shows 2 decimal places and 0 as yours is set to now round to the nearest whole number. I have just been sat at my desk trying to work this out as my calculator was too set to '0'. Took me reading the 'DEC DET' text with lines pointing at 'M+' and 'C.CE' to finally crack it!
Hope this helps.
Apr 04, 2011 | Sharp ELM332BBL Calculator
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
I have done something so the calculator is only displaying whole numbers and will not show anything after the decimal point. Thanks!
Hello
The floating point number display (FIX) is set to zero decimal digits. All your. numbers with decimal parts are rounded.
Look for a key that says [FIX]. Press it and enter a number say3 If I guessed right (Sharp makes numerous calculators) your numbers will show 3 decimal digits.
If there is no such key look for a [MODE] Button. Press the button. If you have a new screen with differents choices look for Format, Float,
On some older calculators there is a table below the display. At the left of the table one finds MODE--> or -->MODE
If it says there Mode DEG:4 that means to have angles in degrees you enter [MODE][4].
I think I exhausted all possibilities. Without you model number, I cannot do more.
Hope it helps.
Sep 04, 2009 | Sharp Office Equipment & Supplies
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
Decimal point
You need to put your tab where it says K*A and set that to A (it is the 3rd set of buttons) and then you need to go to the 5th set of buttons that show F 6 3 2 1 0 and set this to 2. Hope that works :o)
Oct 02, 2008 | Sharp EL-2196BL Calculator
May 05, 2008 | Office Equipment & Supplies
Mar 19, 2008 | Sharp EL-1197P Calculator
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
