Question about Heybrook HB2 Speaker
Where can I get replacement black foam speaker grilles for my excellent HB2 speakers I have been using since 1982 ?
# 1991 peavey classic chours 2x12 scorpion speakers one speaker makes a buzz noise only on a high e note only sometimes -if i want to replace the speaker do the front grill come off to remove spekaer
Normally on older Peavey amps the grill is on a frame attached to the face held on with velcro. I suspect you have something vibrating against the speaker if it's only one frequency. Once the grill is off it may be apparent.
Also on old Scorpions and Black Widows Peavy has a piece of foam in the hole in the magnet to keep junk from getting in the speaker. Over time it crumbles and opens that hole, but even worse can get it the gap and freeze the voice coil. I always suggest cleaning it out while the speaker is out of the cab.
Nov 12, 2016 | Peavey Music
Looking for Speaker grille foam 10mm x 1m x 10m and Speaker foam sealing tape
Try Amazon it looks like there are plenty of sellers on there for grill foam.
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=speaker+grill+foam&rh=i%3Aaps%2Ck%3Aspeaker+grill+foam
Nov 23, 2015 | Audio Players & Recorders
What would make a easy home repair fix for the outer foam on a woofer speaker
Repairing a speaker surround is not difficult. There are ebay sellers such as Loonytunes or Orange County Speaker who sell complete kits for maybe $20 or so for a pair of speakers. Get the kind with white glue--it's easier to work with. Be SURE to get the ones for YOUR SPECIFIC SPEAKERS!
Here's a store with lots of kits http://www.ebay.com/usr/thespeakerclinic?_trksid=p2047675.l2559
This seller does not use shims and new dust caps but has an excellent reputation: http://stores.ebay.com/looneytune2001
Forums such as AudioKarma are good resources. You can also find Youtube videos that show how to do it. Re-foaming is not hard but there is no "quick fix." You have to completely remove the old foam, clean the mounting surfaces, cut off the dust cap and shim the voice coil, install the new surround then install a new dust cap.
Or send the drivers to Millersound.
Jun 22, 2015 | Audio Players & Recorders
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
Repairing 1/4inch tear in foam around sub
click the picture for product website
I used this stuff to repair a tear in the rubber surround on a kicker solobaric 10", it has held up for 10 years, seal the front and back if possible and allow to dry/cure completely. good luck :)
Feb 14, 2010 | Car Audio & Video
I have lost the high frequencies on one of my speakers??
this means your tweeter is blown. check for either replacement tweeters or if its more affordable a new speaker.
Jan 14, 2010 | Heybrook HB2 Speaker
I need the black plastic cover with nylon mesh over it. My speakers are fine but they need the front covers!
You can usually get replacements from the manufacturer depending on the units age. If they are molded grills that are specific to that speaker only you can also try THE PARTS STORE online. You can type in the make and model of your stereo and possibly get parts there. If they are just square grills....Parts Express sells adjustable frame kits that may work or Foam covers that are held on with velcro. The last resort is ebay. Many sellers part out speaker parts and may even have another complete unit cheap with covers.
Jul 18, 2009 | Audio Players & Recorders
Csi sp-6c removal
Your speaker cover should either twist and gently pull off or may just need gentle prying with a small screwdriver. Before attempting is your speaker grill foam or metal. Some like my pioneers, you must gently remove the actual grill and not the entire facia itself to access the speaker removal. If you need to remove the grill, i recommend using a tiny screwdriver and gently work around the edges evenly. Steve
Dec 15, 2008 | CSi Speco SP-6C Main / Stereo Speaker
How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Oct 27, 2008 | Logitech Z-340 Computer Speakers
How do you replace the front door speakers in a 1999 Model Hyundai Excel?
You have to take the door panels off.
The front speakers are 6"
So remove the front door panels, unbolt the factory speakers, bolt the new one in the existing holes, reinstall the door panels.
The grills will look factory, but you will have better speakers. Nice way to keep the good stuff hidden from prying eyes.
Oct 19, 2008 | 1994 Hyundai Excel
Heybrook HB2 Speaker Logo
120 people viewed this question
Top Heybrook Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Heybrook Audio Player and Recorder Expert? Answer questions, earn points and help others
