Question about Ecoquest Flair Air Purifier
The unit is plugged in, turned on but it does not run. no sound. no nothing. suggestions???
    Brigadier General:
  • 4,736 Answers
Check the fuse on the back of the unit to see if it's blown. Also, be sure that the tab on the filter frame is making adequate contact with the safety trigger device, on the back of the unit. In addition, be sure that the outlet the unit is plugged into is working.
Posted on Mar 31, 2011
I have power to my air purifier, the light blinks, nothing else happens
Hi there! It sounds like the rear grille may not be on properly, this will prevent the air purifier from running. Try removing the rear grille and replacing it, making sure it is securely closed. Also, be sure the unit is sitting on a flat level surface as this too will prevent the unit from running. Hope this was helpful!
Sep 25, 2014 | Hoover WH10100 Air Purifier With Ionizer
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
Should I run unit with windows open and atic fan on????
It seems that you would be changing lots of air volume with windows open and the attic fan on. I suggest turning off the unit unless the room is closed, so it can recirculate and clean THAT air.
May 25, 2011 | Oreck Walnut Air Purifier Air8Wa Air...
Have Kenmore 85501 Air Cleaner. Unit will not restart after power failure. Send unit to Sears Service Center but they declined to fix unit. Tried to hold timer and function buttons for 5 seconds and...
Turn the Master ON/ OFF Switch to OFF and unplug the unit. Wait 12-15 minutes and plug the unit back in. Turn the Master ON/OFF Switch to ON and set your controls. The 12-15 minute timeout should have allowed the unit to reset itself.
Apr 16, 2011 | Kenmore EnviroSense 85501 Air Purifier
Absolutely nothing happens when i turn it on, it says to check fuse. how do i figure out where the fuse is
The fuse is contained in a compartment just above, but integral to the plug receptecle on the unit (where the cord plugs into the unit). First unplug the cord from the unit. Next pry the fuse out with a small straight screw driver. If you own the 110v version (as opposed to the 220v unit) you'll need the 1.6 amp slow blow fuse. For the 220v unit use the 1 amp slow blow fuse. Just match up the fuse you remove from the unit. The above information was found in the manufacturerers owner manual. Found online at: http://www.ecoquestintl.com/support/US40135_Fresh_Air_Owners_Manual.pdf
page 7 - Changing the Fuse
Nov 17, 2009 | Ecoquest Flair Air Purifier
Ionic breeze quadra not functioning
I had the same problem and could not find an answer anywhere. So here's what I figured out. The small wires running from top to bottom just inside the cover are your problem. Not the metal grid with plates that you can remove. The buzzing sound you heard is the resistance one or more of the wires is causing. The resisitance tells the pc board that your grid must be wet and therefore the unit goes into drying mode. I replaced my small wires and my unit is working better than ever. The wire is .005 diameter( important so that you keep the same resistance flowing to the pc board) and can be purchased at any good suppy house. I have since repaired another unit with an even simplier fix. I took the unit into a dark room and then turned it on. Watching the grid I could see the wire arching that was causing the resistance. Unplugged the unit, turned it over and with a flat head screw driver pushed the wire off its base connedtion. Turned the unit right side up and removed the wire from its top support. The unit works fine without the troubled wire. Hope this helps.
Apr 04, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Breeze just stop running.....
At the rear of the unit is the filter. When the filter is removed, the small screw or whatever it is called, that is attached to the filter on the lower right side, disengages the the safety switch just below the filter on the unit itself, if there is nothing to hold down this safety switch the unit will not operate. So take off the filter, there is a small notch on the unit, inside this notch is the safety switch, Try pressing down on this switch and see what happens. I hope this helps. Also, it may be the fuse.
Feb 28, 2009 | Ecoquest Breeze AT Living Air Purifier
PLEASE HELP!!! Dead purifier
the machine is fixable its just troubleshooting now, if you have a volt meter check to see if you are getting 120 volts through the cord to the switch, then see if its getting voltage pass the switch
Jan 15, 2008 | Ecoquest Living Air Classic Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Ecoquest Flair Air Purifier Logo
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
