Question about Canon Pixma MP500 All-In-One InkJet Printer
Network Setup for Pixma MP970
I am able to get my printer to operate directly from the computer but trying to set it up on wired LAN is a different story. When I get to the section of Setting Printer IP it will not connect. I have tried every possible way. One suggestion is to try next address. What is the address as there is nothing in the manual as suggested- either printer or computer. Also at this point it starts asking if a LAN connection is connected. I can't work out why when the setup connection is to be done with USB.
Unfortunately I am one of those users who just wants to plug in the printer and go. The instructions are very unclear and difficult to follow. Can you help?
Mike Williamson
  • mikewill Aug 05, 2008
    To my knowledge all firewalls and security were turned off as required by the manual. I have copies of the manual which is no help. Also to do an online fix puts my computer very much at risk.
    Mike Williamson
    Genius:
  • 3,422 Answers
HI,
the easiest way to do it is to go to the computer with the printer attached, go to control panel, and printers, right click the printer you want to use and click sharing.
click the radial button "share this printer" and give it a meaningful name.
the go to your laptop, go to start, run and type the ipaddress of the computer connected to the printer in the form
\\nnn.nnn.nnn.nnn\ this will bring up all the shared folders and printers available on the computer. right click the printer and choose connect.
the rest of the process will be similar to installing a normal windows printer. it will appear in the windows print menus like any other printer.
of course you will need to leave the main computer powered on, not necessarily logged in, to be able to print from the laptop.
Posted on Aug 05, 2008
  • Priya darshan Aug 05, 2008
    Please don't forget to rate or accept the solution.
  • Canon Master
  • 6,487 Answers
If your printer is connected wired directly to a router , you can just let the printer get its IP address from your router and don't forget to set the printer as a network printer...
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 05, 2008
    To set a Windows XP/Vista computer to print directly to a printer, follow the steps below:
    1. Click Start, then Printers and Faxes (Windows XP) or Windows icon, Control Panel, Hardware and Sound, then Printer (Windows Vista). Double-click Add a Printer to start the "Add Printer Wizard," then click Next.
    2. You will be given an option between Local Printer and Network Printer. Select Local Printer. Make sure the Automatically detect and install my plug and play printer is not selected (Windows XP), then click Next. Select Create a new port in the Type field, then select Standard TCP/IP Port. Click Next (twice in Windows XP).
    3. In the Printer Name or IP Address field, enter the Domain (host) name of the printer (e.g., printToMe.dartmouth.edu) which you received from the Hostmaster in response to your request for a fixed IP address. Click Next, then Finish.
    4. If you are placed back in the Select the Printer Port window, make sure that Use the following port is selected. From the list, select the Standard TCP/IP Port you just created. It should appear at the bottom of the list. Click Next.
    5. Select the manufacturer and printer model, or select Have Disk if you are going to install the drivers from a CD or have installed them from the Web. Click Next.
    6. In the Name field, enter the name that will identify your printer on your computer. Specify whether you want this printer to be the default printer. Click Next. Select Do not share printer, then click Next twice. Click Finish. The printer should now be accessible from your computer.
    7. You should be able to print a test page on the printer.
    Hope that helps....
  • Canon Master
  • 13,433 Answers
It indeed is a bit of a complex problem as you may have a firewall program and it may be blocking the connection also.
Best to try following the manual, or we could do a remote support session tomorrow and figure it out.
the network setup guide is available in the downloads section of this webpage
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15481
  • 1 more comment
  • Ekse Aug 05, 2008
    Page 7 in the manual.
    can you follow those instructions? do you want me to set it up with you?
    The program I use, is very simple, fast and secure. there is no risk to your computer, the risk to your computer is having your firewall off, you can turn your firewall On while I help you with remote support.
  • Ekse Aug 05, 2008
    actually its probably better that you turn the firewall on right away.
  • Ekse Aug 05, 2008
    I would suggest to try following the instructions on page 7, step by step, don't rush, take your time.
My cannon MG5220 printer will not scan but prints fine. i keep getting an error that says "cannot communicate with scanner for these reasons: -scanner is turned off. -scanner is disconnected (It is...
Many printers will not scan over a network, even when they are supposed to. Try connect to it with a standard USB cable and scan to PC directly. If that doesn't work - you have probably got a faulty scanner.
If the scanner works OK directly to a printer, then your issue is either LAN/WLAN bandwidth or an unstable IP address. Try fixing the IP Address rather than running DHCP address allocation eg set it at 192.168.x.150 where x is the range value for your network. Then set the printer port address on your devices to the same values and try again.
Nov 27, 2017 | Canon PIXMA MX870 Wireless Office...
Tip
Configuration of NETGEAR router as Access Point: The below steps illustrates the...
The below steps illustrates the usage of router's like WGR614, WGT624, WPN824 as an access point to extend the wireless network in your location. The only required setup is that you should have a DHCP server running on your network ( be it your modem or a different router).
1. Connect a computer directly to NETGEAR router on any of the four LAN ports.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on wireless settings in the left hand side menu Under Setup.
5. Change the network name SSID to some other name.
6. Select security options as 'WEP (Wired Equivalent Privacy)'.
7. Set the 'Authentication Type' as 'Automatic' and Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
Click on LAN IP setup from the left menu.
1. Change the IP address of the router from 192.168.1.1 to a free IP of your existing DHCP network.
2. Also disable the DHCP of the router by unchecking the box for 'Use router as DHCP Server'.
3. Click apply and click ok for any popup message that arise.
4. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, turn off the router and restart the computer.
Now, connect the two router in the following way:
1.Connect Ethernet cable from the Lan port of the existing router/modem to the Lan port of the NETGEAR router.
2. Powercycle both the routers and your computer
3. You may connect other computers' directly to NETGEAR router or wirelessly as per your requirement.
on Mar 18, 2010 | NetGear WGR614 Wireless Router
Tip
Drivers and Manuals for PIXMA MP970 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma MP970 photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads mp730 but the actual page linked will be for mp970 d0c0d3b.jpg
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MP970 InkJet Printer
I cannot install my Epson workforce 600 and get it to accept the IP address for my cisco linksys E1000 router.
I actually own a workforce 600 printer... they are nice for photos... anyway, the following solution only applies if your router is configured as a DHCP Server... This is the default setting, so if you don't know, then it is probably is configured as a DHCP Server. So, First, plug your printer directly into the router (wired connection) Then, load all drivers and software onto your computer. There will be one program in particular that you want to use. It is called "EpsonNet Config". Open that program (it is located in start---> all Programs--->EpsonNet---> EpsonNet Config Vx ) If your printer does not show up, you must verify your network settings on the printer (First make sure your wireless is disabled in Setup ----> Network settings --->Wireless LAN setup ----> Disable.... Then, Setup ----> Network settings ---> general network setup ------> "Yes" ---> press"ok"----> "Auto" ---->press"ok"---->"yes") Now, go back to EpsonNet Config on your computer and click refresh (upper left hand corner). When your printer shows up, double click on it. In the left pane click on network---> basic (wireless). In the right pane, click enable wireless LAN, then type in your SSID (routers name). DO NOT CLICK TRANSMIT YET. Then, in the left pane, click "network ----> security". In the right pane, put in the appropriate security level and key for your router. This information you would have configured when you setup your router. Now... click transmit then "ok". Wait for the settings to transmit 100%. now you can remove the network cable... verify that EpsonNet Config still can see the printer. and you are good to go. I hope this helps.
Livingmentor
Mar 22, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Actualy i dont know how to set it...i wqant to print but i could not not print...its new one...so i dont know anythng abut it...would you help me to set the printer and print on it
Hi reetmalhotra,
Canon do supply a wireless setup program for your model which will guide you though the process:
Canon PIXMA Wireless Setup
By clicking the link above you will be taken to this page where you can download the software:
Canon PIXMA Wireless Setup Assistant is a tool which enables you to confirm the access point name and network key required when setting up a wireless LAN connection.
Feb 22, 2011 | Canon PIXMA MX870 Wireless Office...
My wifi for my epson nx515 is not working with my laptop.
Obtain the IP address of your printer. Go to Setup > Network Settings > Confirm Settings If it starts with 192, that's good. If it's 169 or 0, do the ff : --- 1. Reset the Network settings. Go to Setup > Restore Default Settings > Network Settings 2. Run the Wireless LAN Setup. Go to Setup > Network Settings > Wireless LAN Setup 3. Make sure you can see your network name or SSID which is provided by the router manufacturer. 4. Enter your network key and enter it as it is (CaSe sensitive). 5. Obtain the IP address. Make sure it starts with 192. 6. Now run the software on your computer and add the printer.
Dec 08, 2010 | Epson Office Equipment & Supplies
How do you change the ink cartridge on a pixma mp970
Simply lift scanner bed and watch the cartridge carriage centralise for easy removal.
Mar 30, 2010 | Apple MFC Canon Pixma MP970 Drucker...
No usb cord in box
this is straight from canon.com
dot.gif PIXMA MP970 All-In-One Printer dot.gif Power Cord dot.gif Print Head dot.gif Ink Tanks:
PGI-5 Black
CLI-8 (Black/Cyan/Magenta/Yellow/Photo Cyan/Photo Magenta) dot.gif Document Kit: Cross Sell Sheet
Easy Setup Instructions
Network Setup Guide
Quick Start Guide
Setup Software & User's Guide CD-ROM so it looks like you'll have to purchase a usb cord.
Mark
Apr 30, 2009 | Canon MP970 Photo All-In-One InkJet...
Wireless Printer Setup
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it0 1is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
Feb 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
907 people viewed this question
old marine
old marine
