How to replace broken hinge on hp officejet j6450
  • 1 more comment
  • rwicker2346 Mar 31, 2011
    the left hinge that opens to change ink cart., its broke
    i have a broken hinge on the left side of my printer. it's the hinge to gain access to change ink cart. it is a hp officejet j6450
  • Anonymous Jul 29, 2015
    The suggestion to remove the hinges was brilliant. You just need to remember to remove all 5 screws on each hinge 2 front 3 back and wala. My printer will likely work for years to come.
    Brigadier General:
  • 3,513 Answers
Hi
You need to replace the broken hinge. Unless you find a replacement try removing the broken top half of the hinge and let the machine work. Remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (You have to be careful to hold it in place so as not to damage the three flex connections between the lid and body )and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 31, 2011
  • 656 Answers
Can you please clarify which hinge is broken you can stick them with gum which sticks quick if the hinge is need to give pressure like the cartridge hinges i think you wont be able to fix them it
  • rajesh raman
    rajesh raman Mar 31, 2011
    Take a flexible plastic of small size of desired length which should not break when folded. It should be flexible and paste the flexible plastic to the cover and the printer it will work as hinges. The plastic should be gummed in the inside of the cover so no one will see it
Scanner lid hinge broken or missing
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 01, 2014 | HP Officejet 6700 Premium E-All-In-One
The hinge on the cover cracked. Can this be replaced?
I used an offset cabinet hinge & screwed it into the body of the printer, & the cover. The offset has to be jiggled a bit to open, but works fine on closing.
Otherwise, HP wants you to buy a complete new scanner cover.
Dec 07, 2010 | HP Officejet 6310 All-In-One InkJet...
HP officejet 6210 broken hinge on cover to access the print cartridges. Fixable and where can I take or fix myself?
The 6210 series are famous for broken hinges, plastic and under spring loading. One place has them but at $88 for a set it may be not worth it. See link below if interested. I have one too with same problem.
http://www.everprint.com/online/SimDetail.asp?partno=q8052-40001
Jul 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can I get parts to replace broken hinge? I have an HP Officejet 6210 All in One.
In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Dec 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
2,185 people viewed this question
jasbo
jasbo
