Question about Sharp EL-1801P Calculator
How to change a ink roller on SharpEL-1801C - Sharp EL-1801P Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: how to replace ink roll for sharp calculator
Here is the manual on link below on page 5 tells you how to replace.
http://dl.owneriq.net/e/ea19126b-3714-4b3d-bce5-712458b60c6d.pdf
Good luck and please rate 4 thumbs for the free answer
Posted on Mar 14, 2010
Where can I buy a replacement 2-color ink ribbon/roller, whatever it is? I've looked...
If you are in the UK try Staples and Ryeman...if the latter is still about
In the rest of the world.....you must have famous stationers who still stock such things
Jul 20, 2015 | Sharp EL-1801C Calculator
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
How to change the tax rate on a Sharp EL-1801C calculator
Enter the desired number for the tax rate... followed by hitting the "STR" button... followed by hitting the "Tax+" button. Here is a link to the manual for the Sharp EL-1801C. http://bit.ly/lf3edL
Jun 19, 2011 | Office Equipment & Supplies
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
I cant find where the ink cartridge is on the sharp EL-180P
Not familiar with your model but others I have serviced used an ink-impregnated roller rather than a ribbon; you may be looking for the wrong object. They were generally rolling directly on numeral roller.
Apr 15, 2010 | Sharp EL-1801C Calculator
How to replace ink roll for sharp calculator EL-1801c
Mar 12, 2010 | Sharp EL-1801C Calculator
How to change ink roller on Sharp Calculator EL-1611H
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover.
Apr 19, 2009 | Office Equipment & Supplies
Need to change the ink Roller
Remove the top cover. You should see a little black tap that says pull up (the ink roll), do so. Then pop your new ink roll in. Replace cover.
Mar 16, 2009 | The Times ROYAL TC100 TimeMaster Time...
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Sharp EL-1801P Calculator Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
