Question about GTCO Roll-Up Digitizer, 30/36" (RU3036)
GTCO Roll-Up II digitizer suddenly stopped working...On boot up I get a message telling me the the tablet is not found. I checked all connections and verified the driver to be current according to windows update (driver 7.46.619.0). When I unplug the power and plug it back in I get 4 beeps. The device manager recognizes the tablet and indicates that it is functioning properly. I've been using this tablet several times a week for about 6 years...I haven't changed anything with this setup and now all of a sudden it is not working. Any help would be greatly appreciated.
  • droy485 Mar 31, 2011
    Thank you for the reply, can you tell me which is the ribbon cable? This unit has three cables coming out of it: the power cable, the mouse/pointer cable, and the data cable connected to the PC. I have checked all and they seem okay. Also, when I go to install the driver you linked there is a warning that comes up saying that this is a generic driver and I may lose functionality if I replace my existing driver with it.
    Do you recommend replacing the driver? I am currently looking through the manual as well.
    thanks!
    President:
  • 3,278 Answers
Hello.
There may be a problem with the GTCO Roll-Up II driver (software to run the tablet).
Here is a link to find the driver, in case you don't have a copy.
http://www.getdigitizers.com/Roll-Up-Digitizer_c_109.html
Select Drivers next to Roll-Up II and Save then Run the TW-10.9.24 file.
If not the driver, then check the ribbon cable connections on both ends. Disconnect and then reconnect the ribbon cable to be sure it is seated well. Then press the reset button on the controller.
If still a problem, check this printable Help file, if you don't have a copy of the User Guide:
http://www.gtcocalcomp.com/files/rudii.pdf
Hope this helps.
Posted on Mar 31, 2011
  • NinaE Mar 31, 2011
    Hi. Normally a ribbon cable is a soft, wide cable. But, it's not the power cable or the cable connected to the mouse. It's possible that the data cable is faulty. I would not recommend replacing the driver, if it is generic. Did the help file assist you at all with any troubleshooting of the beeps ?
How is this hooked up and how does it work
This pen will only work with GTCO SLX or Cordles Roll-Up products.
Install a new battery and it should work on a SLX cordless tablet or a Cordless Roll-Up.
Jan 11, 2012 | GTCO Cordless Stylus Pen w tip switch and...
How to set up mouse on paydirt software, currently working in reverse
This could be a problem in Paydirt or the setup of the digitizer.
The Roll-Up II and Roll-Up III digitizer would allow you to change the orientation from one side to another,check this first.
The 0,0 point should be at the left hand side of the Digitizer where the metal housing and connections are.
There is a selection on the menu to change this,it looks like a double-headed arrow.
Sep 20, 2011 | GTCO Corded 16 Button Cursor with 3 meter...
I have a garment CAD of China, my garment CAD of China can connect to GTCO Roll-Up Digitizer, 30/36"
Hence please mention the fault that is seen with the CADin coonnection. We at fixya can help only with more clarity on the question.
Sep 25, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
I HAVE AN OLDER MODEL GTCO ROLLUP II DIGITIZER (3036R), BUT CANNOT LOCATE DRIVER DISK(S)---- WHAT IS THE BEST WAY TO OBTAIN A DISK? B.C.
You can try the Tech Support section at GTCO.COM or vtablet.com,on vtablet the drivers aren't free and will have to be purchased.
Aug 29, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
I have the stand-alone system with the LCD screen,
These original Roll-Up I Digitizers didn't use a power supply,all of the power came through the Com port connection.
The Roll-Up II used a 9 volt center positive power adapter.
May 14, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
The GTCO digitizer roll up board was folded and now has a crease.
No, the lines in the Roll-Up are probably broken.
If you send it to GTC for repair, they should give you a discount on a new one.
Jan 29, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Looking for a manual for a 3648 III roll up
Go to www.gtco.com, select Tech Support/Large format Digitizers,then select GTCO Brand on the bottom of the screen, then select documentation and a PDF file can be downloaded.
Dec 17, 2009 | GTCO Roll-Up III Digitizer Graphic Tablet
Calcomp GTCO Roll upDigitizer
Go to the search on your computer and find your tabletworks. Open tablet works and go to mapping. Click pick. Locate your mouse pad on the digitzer pad. Click Apply. This worked for me.
Mar 29, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Wont recognize gtco digitizer on start up
First reset digitizer and make sure you hear four beeps and only four beeps.
Check the cables from the Quikruler to the interface module, make sure they are in good condition, no cuts, breaks missing pins on connector.
Check cables from interface module to digitizer. A good way to check for an intermittent problem is to bend the cable at different points and check the display on the Quikruler to see if has reset.
Select S01 on the superset code with your stylus or cursor. You get get four sucess tones (beeps).
If none of this works check the firmware version on the digitizer, some J2.0 firmware may become corrupted. When the firmware becomes corrupted, you will hear three(3) medium tones on power-up.
If this is happening it will have to be serviced by GTCO.
Feb 06, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Computers & Internet Logo
274 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Ciricuario Dh
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
