Question about Singer Featherweight 140Q
When sewing, needle stops as it is hitting top of bobbin case - raceway system does not seem to be secure; keeps falling out
    Problem Solver:
  • 10 Answers
Need to know make and model of machine
Posted on Sep 03, 2008
SOURCE:
How to fix bobbin timing?
Check to see the bobbin case is in fully, and the shuttle race cover is secure. Also make sure the needle is not larger than specified for the machine (many machines can't cope with size 18 or 19 needles!) Also check to see if the needle is of the right needle system (not a serger needle!), and fully up in the needle clamp. The needle package should show one of these needle systems: HAx1, 130R, 130/705H, 15x1, SY 2020.
See: http://sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
May 25, 2014 | Brother CE4000 Computerized Sewing Machine
Bobbin Mechanism
There are two types of bobbin mechanism, rotary and oscillating, rotary goes one way and oscillating goes back and forth, if the needle is hitting the bobbin case or raceway either the needle is bent or thge machine needs retiming
Sep 29, 2013 | Sewing Machines
I was sewing along with no problem and then all of a sudden it jammed. I can't move the needle up or down without a lot of force.
There is probably thread jammed in the raceway area, take out the bobbin case and raceway if it is a front load bobbin
Aug 05, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
Needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
Jul 04, 2010 | Brother XL-3510 Mechanical Sewing Machine
Thread stuck around the bobbin housing on my
try cleaning all that you can out of the bobbin case then try very carefully to bump it backward (opposite) with the hand wheel . Be careful not to knot out of timing. sounds like you have thread in between bobbin case and hook
Apr 06, 2010 | Consew 339RB-3 Sewing Machine
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Mar 10, 2009 | PfaFF Tiptronic 2040
Timing Lag.
Are you sure the timing has gone,?
Check these first, needle in the correct way round, threaded properly, needle not blunt or bent.
If the machine still misses stitches arfter checking this then it needs retiming, select straight stitch, take off the needle plate, take out the bobbin case if you have a seperate bobbin case, and undo the two clips to take off the race cover, if you have a drop in bobbin just take out the bobbin, take the bottom off the machine so you can see underneath the raceway, tilt the machine back it will be easier, turn the balance wheel by hand towards you so the needle is going down into the machine then on its way back up, just as it starts to go up stop, look at the point of the hook, it should be just above the eye of the needle, if it is not undo the screws on the vertical gear underneath the raceway and you can move the hook round to where it should be, tighten and put the plate and parts back and test sew, if you have a front loading bobbin case undo the screws on the shaft of the raceway and move the hook round to where it should be, it may take you several attempts, if the machine sews perfectly on straight stitch test it on wide zig zag, if it misses stitches one side you will have to start again moving the hook either side slightly until you get it right thx nick
Feb 01, 2008 | Bernina Virtuosa 160
Singer Featherweight 140Q Logo
76 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
