I have a 2005 Whirlpool washing machine, LSR7233EQO model number. It has filled with water, and won't spin or drain. It is making a noise - is there a reset button that I could push to help me drain the water? Thank you!
  • 5,911 Answers
The most common cause of the symptoms you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the initial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that may not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are tight. Sometimes these screws will loosen, causing the lid switch make intermittent contact. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list, include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The lid switch and associated components are usually listed under the "Top and Cabinet" parts listing.
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
The part numbers for the model you have listed are as follows: LID SWITCH 3949247, LID STRIKE (Actuator) 358684. If you have questions, please post back and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you
Posted on Mar 31, 2011
Washing machine will not drain water
Here are some basic troubleshooting steps you can follow to help you determine why your washing machine won't drain:
1. Check the drain hose in the back of the machine and make sure it isn't kinked or flattened.
2. If it spins but won't drain, there could be a piece of fabric stuck between the inner and outer tub, or even the drain hose or pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. It could also be a faulty timer.
3. Are clothes soaked at the end of the wash, even though it appears to go through the spin and drain cycles? Worn or loose belts could be the culprit.
4. When the spin cycle starts, do you hear a humming noise? It could be a faulty or jammed impeller pump.
For more suggestions on troubleshooting and fixing this issue, check out Washing machine not draining. I hope this helps!
Sep 11, 2012 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
The tub on my whirlpool washer fills with water but will no spin
If the washer will fill and drain, but won't agitate or spin, this is usually a sign that the motor coupling has broken. The noise of the motor engaging, lack of agitation and ability to still drain are common symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you have questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Sep 25, 2009 | Washing Machines
Whirlpool Ultimate Care II - making funny noise
this is probably a bad motor coupling, you have to take the cabinet off, then the drain pump, then the motor, the coupling is located between the motor and the trans
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Washing Machines Logo
176 people viewed this question
Top Washing Machines Experts
