The left speaker or controlling speaker has no ... very little sound.. the right one is working. I have them hooked up to a computer with the earphone jack which splits into right and left jacks.
    President:
  • 2,340 Answers
Right click on your volume icon at the taskbar, & open your volume control. Check if the Master Volume - "balance" is at the center!!
Check your speaker connecting cables are securely plug in.
Hope it helps.
Posted on Mar 31, 2011
Computer was wiped clean but left my Boston speakers hooked up and now they don't work and have no sound...where do I find a driver or something to fix this problem
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 01, 2010 | Boston Acoustics BA745 Computer Speakers
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
I have a new dell inspiron. I just purchased Logitech x-540 surround sound speaker system. The right front, left front, and center speakers don't work. Everything seems to be hooked up right. Any ideas. Is...
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
Feb 21, 2010 | Logitech X-540 Multimedia Surround Sound...
I've tried three different sets of speakers and each time the left speaker will not work. I've also tried plugging in my headphones and my left headphone wont work. I've checked all the volume controls and...
Well the jack you plug in has three surfaces. So when you pulled it part way out then the left speaker part of the plug came in contact with the right speaker contact inside the jack and it worked. Speakers are good so if you have checked your volume control in Windows and checked that the balance control is centered it could be that your sound card is defective. You didn't tell me what kind of computer you have and if the sound card is built into the motherboard or if it is an add on card. I don't know if you only have the Window's sound control in Control Panel or if your card has a seperate software for configuring your card but I think the only thing that might disable the left speaker has to be the balance control in Window's sound control or the seperate software.
Nov 15, 2009 | JBL CREATURE II Computer Speakers
My speakers not working to my computers
check o see if the speakers are working on something else. if so make sure your computers volume is turned up. you can do this by looking to the bottom left hand side of the sreen , you will see a little speaker. double click it and your volume controls will appear.
if you do not see a little speaker then most likely you will need to reinstall your sound drivers.
Nov 14, 2009 | Office Equipment & Supplies
I have a SBS 5.1, only one speaker is working. what should i do to have all the speakers to work
First test the "non working side" with the speaker which is on the good side. Hook it up on that side and turn on the system. Make sure to go from left to right to left on the volume control pop-up or in the control panel, if it is Windows.
If the test above indicates that you get no sound, then the sound card is suspect.
If this is a removable card, it may be possible to put another sound card in.
Aug 30, 2009 | Creative Labs Audio Players & Recorders
I just hooked up my Labtec LCS-2420 speakers to my new computer and can't get any sound out of them. I can get the cheap ones that came with the computer to work, but not the Labtec. I hooked them up to...
if its a 6 channel connection its a little tricky try reconnecting your speakers that has a green connections. try playing a music while troubleshooting the connection...hope this helps..ITTech7574
Aug 29, 2009 | Labtec LCS 2420 Computer Speakers
Just need to know how to hook up proper for stereo sound
start with the right speaker, that is you control for now. plug in the power supply one end to the wall the other to the right speaker, connect the left and right speakers, connect the sub woofer to the right speaker, (most of the plug and sockets are color coded, or at least different sockets sizes so they will only fit properly with the correct connector) now you should have one wire left coming out of the right speaker-that gets connected into the GREEN socket of you computer.
Now you should get sound...good it works.
From here we go to START->SETTINGS->CONTROL PANEL->RIGHT CLICK ON SOUND AND AUDIO DEVICES->VOLUME TAB->ADVANCE (TO THE RIGHT OF SPEAKER VOLUME->SPEAKER SETUP->FOR THE DROP DOWN ARROW SELECT DESKTOP STEREO SPEAKER->APPLY->OK
And that my friend is properly done.
enjoy,,, please leave a rating, thank you
May 10, 2009 | Computers & Internet
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
56 people viewed this question
 Grubhead
Grubhead
