Question about HP Keyboard/Mouse
When I type A, the alphabelt asdfj appears instead of A. Also when I type 1, the number 1234 appear instead of 1.
Need radio code for 2006 suzuki FORENZA
A local dealer can help. They will have a code based on your VIN. Also, you can try this: The audio security system is activated whenever the audio system circuit is disconnected from the battery. A four-digit security code must be entered in order for the audio system to resume functioning. The security code is stamped on a card located in the vehicle (usually in the glove box). The following security code entering procedure must be used to deactivate the audio security system:
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
If, after repeated entry of the wrong code, unit will enter "lockup" & will need to be repaired
Oct 07, 2015 | Suzuki Cars & Trucks
How do I get my radio to work after I changed my battery. I have the radio code. It is a 2004 Suzuki forenza
Hello there
I found this in a suzuki forum
Hope this helps.
If code doesnt work then it is dealer, sorry.
Sep 24, 2014 | Cars & Trucks
I am trying to start my page numbers on 10 instead of 1
  1. Double-click anywhere on the header or footer to unlock the Design tab in the top menu.
  2. Click the Page Number command. In the menu that appears, select Format Page Numbers
  3. A dialog box will appear. Click the Start at: button. By default, it will start at 1. If desired, you can change the number.
  4. Click OK.
Good Luck :)
Feb 26, 2014 | Microsoft OFFICE 2013 HOME AND BUSINESS 1...
Medion notebook typing normally. getting numbers instead of letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 05, 2012 | Medion md40298 Notebook
At start up the ACER logo appears as is normal and then instead of going through the remainder of the boot process, the following appears on the screen (with a solid black background): Windows could not...
For the Hal.dll file missing problem do this:
1.Insert and boot from your WindowsXP CD.
2.At the first R=Repair option, press the R key
3.Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4.Type bootcfg /list to show the current entries in the BOOT.INI file
5.Type bootcfg /rebuild to repair it
6.Type exit and take out the CD ROM
Sep 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
SIM CRAD REJECTED
Sorry for this but is only the service provider that can rectify the promblem. The sim card will be replace and your phone will come to life again. Thanks
May 06, 2009 | Nokia e65 Cellular Phone
HP Keyboard/Mouse Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
