Question about Bose Lifestyle 28 System
No video signal is displayed on my Bose system
2 Suggested Answers
gopakumarg43
  • 75289 Answers
SOURCE: My Bose V30 system with the RCV1T-27 remote wont
Hello
Check the cells in the battery compartment of your remote control handset. Replace it with new ones and check. Still you poise this problem, the intensity of infrared rays come from your remote control, or the sensitivity of the infrared sensor inside your bose front panel system may have the trouble. Just replace the infrared LED of your remote control with an other one of same type. If it does not helps you, repalcing the infrared sensor will reftify your problem. OK.
Posted on May 05, 2011
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
Sep 08, 2014 | Bose 321 GS series II
My Bose V30 system with the RCV1T-27 remote wont send the IR signal to my Motorola DCT 6416 if im not standing right in front of the Bose display unit. The light on the display still blinks as if its...
Hello
May 05, 2011 | Bose Lifestyle V30 Home Theater System -...
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Bose lifestyle 38 has power but will not function at all. The display reads Bose Lifestyle - Try to turn on radio and nothing happens. Tried using remote for second zone and the remote display said no...
The sub is bad.the power supply inside the sub is your problem.If your unit comes on it could also be a defective dsp pcb in the sub.everything in the sub runs the head unit.If you send to bose they have a 175. flat rate.
Feb 12, 2010 | Bose Lifestyle 38 System
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
Bose Remote Control RTC1T-27
I called Firedog and paid them $80 to come out and fix it.
Jan 04, 2009 | Bose Lifestyle 20 System
Hook up
The Bose GS can only support component video set-up for the best video definition. This video connection set-up uses three RCA cables to transfer the video signal from an output device (the Bose GS) to an input device (Your TV).
Check if the back of your GS system has a set of video out RCA ports that are titled "Comp Out". You TV should then have a "Comp In" video input RCA ports you can connect to.
Hope this helps.
Oct 14, 2008 | Bose 3 2 1 GSX System
Bose Lifestyle 28 System Logo
273 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
