Question about Teac Audio Players & Recorders
We own a teac DC-D2801/2830A a cd/tape/record/and raido player. when it is on the cd, the muting button is on and will not turn off with the remote or on the deck. i pressed the reset button and changed the batteries... any suggetions?
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: TEAC V770 3head tape deck.
Hi saabangerman
The unit sounds like it has a take up clutch or takeup idler problem. Check all the drive assemblies in the unit. Remove the cover from the front of the transport inside the cassette well, and check the condition of the idlers and reel base drives. The counter belt can also gatherup and prevent the takeup reel from working correctly, or fire the auto stop mechanism preventing it from playing, although that sounds to be ok in this case as the unit will FF and REW ok. The takeup drive is supplied by a different drive idler as it requires much lower and more controlled torque. This unit was always considered to be a great tape deck and is well worth a bit of attention for restoration. You can get a new belt kit for $19.00 from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
My Teac DC-D2831 has actually two problems: 1) the muting light won't come off during CD mode and 2) the 3 CDs often come loose in the tray and get shuffled around or stacked up. Help?
check your remote 4 damage. an make sure u dont have efx or nothing turned on while u r n cd mode. o yeah cds have different thickness u mite need 2 use skinny cds. some cds u can see thur n some u cant
Mar 14, 2011 | Teac Audio Players & Recorders
How do you raise the recording level on a teac rw d200? Im recording into the recorder from another deck and when i playback its so low you can barely hear it
I have the same problem. Are you copying an analog source? (tape?) Even though the "0 db" level is activated, (button on upper right on front panel) the level rises to -12...max. I suspect the auto-level is preset at the factory? Even with an EQ boost there is no level increase. Drives me nuts! Must have to recalibrate it; but I've no idea how...
Sep 12, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
I need the ir remote codes for a teac cd-rw880
http://dogbytecomputer.com/codes.htm#CD%20CODES
Feb 13, 2009 | Teac CD-RW880 CD Player / Recorder
Read error
try a cleaning disc. Your lens may be dirty
Feb 02, 2009 | Teac CD-RW880 CD Player / Recorder
CDR200
Push CD Sync...when goes into it....push record or pause....like a double tape deck.
Jul 11, 2008 | Classic Electronics CDR201 CD Recorder
Recording
How do i use the finalize button to finalize a cd after recording?
Nov 21, 2007 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
Questions
Swop the CDR into the tape outputs on the amp and use it just like the tape recorder you had hooked up. Also do a direct digital link to a CD player for digital copies.
Aug 18, 2007 | Teac CD-RW880 CD Player / Recorder
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
