Question about HP Computers & Internet
I have the 333000 games DVD and it is limited to windows XP and now I have Windows 7 X84 bit operating system. Is there any upgrade available?
  • santmyer33 Apr 03, 2011
    I asked if there was a way to update 333,000 games which was limited to windows XP and make it good for windows 7. Your answer was to buy a later version of yhe DVD.
    Bob Santmyer
  • 4,281 Answers
Yes you can get it from below for win7. Click here Also try to run games in compatibility mode of xp. For that when you install games in property of setup.exe right click on it then select compatibility mode set winxp also set this in the exe of games. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Mar 31, 2011
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
How to uppdate from Windows Xp into Windows7 I
Well, it depends on your computer specification because every operating system has it own hardware requirements. Before upgrading to windows 7 make it sure your motherboard support the windows 7 operating system. In your case your motherboard supported by the windows 7 so when upgrading rather formatting your computer you must have the windows 7 installer. Then follow this video tutorial on how to setup your computer to windows 7. Before formatting you must have to back up all your data or files saved on your hard drive. Have a nice day
May 27, 2011 | Intel Motherboard
I have "windows7 Home"
They will work with Windows 7 Professional or higher due to a built in "compatibility mode"
All you need to do is... upgrade to Windows 7 Professional. Right Click on the setup icon for the game. Go to properties. Look for compatibility mode. Run it in windows XP mode
And there ya go :)
May 22, 2011 | Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Installed windows 7 now games do not work used to have xp
This occurred due to 32 bit operating system. Your Windows XP was probably 32 bit, for check that, go to "My Computer" properties. And now, your Windows 7 is 64 bit operating system. That's why that game is not running. Try to load a fresh 32 bit Windows 7 to fix your problem.
Feb 01, 2011 | PlayFirst Diner Dash
Problems downloading from camera using windows 7 - error message say windows XP required - is it possibel to upgrade software to be compatible with windows 7
If your OS is Win7 64 bit, then incompatibility must be occur because Windows XP use 32bit Operating System and driver software usually only special for each OS (x32 or x64). About upgrading the software, how will you upgrade while you can't even install the basic software in your PC ? The choice you have is find another driver that compatible with your OS, you can search via Google, and I hope you are lucky enough to get it available or even free to download.
If you still want to upgrade, then the Windows7 is the one to be upgraded so you can use XP Mode system. You must have Windows 7 Professional, Enterprise, or Ultimate to run Windows XP Mode. You can visit microsoft.com for details.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Fuji FinePix F810 Digital Camera
Is it possible to upgrade windows xp professional x64 to windows 7 professional x64
Hello
Yes it is.
Just make sure you download or purchase Win 7 x 64.
If your doing the upgrade you need to have winxp x 64 installed on your pc first.
Jun 10, 2010 | Microsoft Windows XP Professional for PC
I have lost CD 1 of the Lexmark x 85 printer and cant get it to install onto my computer?
These are the Lexmark X85 printer drivers available for download in the Lexmark website:
- Driver for Microsoft Windows 2000 (for Windows 2000 only)
- Driver for Lexmark X84-X85 (for Windows XP only)
- Lexmark X84-X84 Driver for Mac OS X 10.1.x, Mac OS X 10.2.x, and Mac OS X 10.3.x.
If the operating system of your computer is not listed here, that means there is no printer driver available for it. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 26, 2010 | Lexmark X85 All-In-One InkJet Printer
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
Feb 07, 2010 | Microsoft Windows XP Professional
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
