Question about Aiwa AV-X300
Can I use 6 ohm speakers on my 8 ohm aiwa av-x300?
    Top Expert:
  • Aiwa Master
  • 74,243 Answers
Hello
You can use 6Ohms speaker in place of an 8Ohms speaker. No damage will occur to the set, but the quality of sound output will be a little bit less and the output will be a little bit high. OK.
Posted on Mar 31, 2011
I have aiwa nsx-kt9 speakers.kindly tell me how much watt amplifier will be right for these speakers
These speakers are 6 OHMS, that means you can only use an amp that is rated for 6 ohms. The original amp put out 20 watts (rms). Any amp rated above 25 watts per channel could do serious damage to the speakers if turned up to the highest levels.
Apr 07, 2017 | Aiwa Audio Players & Recorders
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Konzert amplifier av 302 can i use 4pcs of 200watts speaker in that amp
It depends on the impedance of the speakers, if you use (2) 8 ohms speaker on each channel the load will be 4 ohms if you use (2) 4 ohms the load will be 2 ohms , check and see what load the amp can handle.
Dec 12, 2013 | Audio Players & Recorders
Impedance setting on Yamaha AV Receiver
Hi. You can always use a Receiver with an output impedance that is lower than the speakers input impedance.Problems arise when you try to use a Receiver with a higher output impedance than the Speakers input impedance.
Receiver 6 ohms speakers 8 ohms......YES..
Receiver 8 ohms Speakers 6 ohms.......YES, WITH CAUTION
Jan 15, 2013 | Yamaha RX-V673 7.2 Channel AV Receiver...
Hi there i jus wanted to know if the aiwa lcx 337 k has RCA connections so i could connect my mixer to it, and also if i could run 200 watt technics speakers through it aswell? cheers
No external tape loops. This is NOT a component system in the usual sense.
Wattage is not THE major consideration, impedance is.I can't find any documentation on this product but these small units are usually spec'd for speakers with less than 8-ohms to tweak the power output figure at a dreadful distortion level. All other things being equal, 8-ohm speakers would require more power so you'd have to crank it more. Overdriving any amplifier (like this one) will create speaker-killing distortion.
Jun 28, 2011 | Audio Players & Recorders
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
Aiwa av x300 and the cd tray never plays just spins
Just clean the lens, cotton bud soaked in alcohol
Nov 25, 2009 | Aiwa AV-X300
TURNING ON, BUT NO OUTPUT TO SPEAKERS.
Try making sure tape monitor is in off position. Also I assume front speaker button is engaged. Another option is that analog setting needs to be changed to digital if digital output
Apr 22, 2009 | Aiwa AV-D67 Receiver
Aiwa AV-DV75
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
Jan 02, 2009 | Aiwa AV-DV75
Speakers started buzzing.
It sound like your getting AC noise, chances are you have some dried out capacitors
Dec 13, 2005 | Aiwa AV-DV70 5.1 Channels Receiver
112 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
