Question about Panasonic Cell Phones
The phone seems to be dead. Instructions say "no link to base." Do I need a new battery in the phone? Does not ring, no voicemail possible.
    Sergeant:
    Champion:
  • 244 Answers
Place the phone on your receiver for a half hour. Give it another try after that.
Good luck
Posted on Mar 31, 2011
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
1.800.297.1023
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
Change number rings voicemail
KX-TGA939T is the model of the handset. Voicemail is controlled by the base unit. What model do you have? Or is the voicemail being provided by your telephone service provider? If the latter, refer to their instructions for customizing their voicemail system.
Jul 03, 2013 | Panasonic KXTGA939T - - Phone
Hi I have a Panasonic cordless phone kx tg2511al. I sometimes find that incoming calls go straight to voicemail without it ringing first. How do I make sure it rings at least a good number of times...
Remove the battery and allow the set to phone to reset. Now check for the ringer setting at teh back of the base phone to be set to the maximum rings, there can be three settings.
Some times this is also set on the menu.
Connect and test the timing to confirm
Jun 13, 2011 | Cell Phones
Hi I am hoping you can help me. I own a Siemens Gigaset A58H handset which up until 48 hours ago has been working perfectly. One day, the voicemail light indicated I had new voicemails and so I went to...
You need to find your manual to the phone in case you need to reset the phone.
When flashing Base like that, it has lost connection to the base charging station. It can be the power to the base unit or the phone cable that is faulty.
In any case the phone cannot connect to the base unit, so my advice would be to check the base unit (normally also the charging station), and make sure that all cables are connected and it is turned on.
It sounds like a bit of a dummy advice, but in my 17 years of experience, it is nearly always a cable problem when described like yours. It can be something as simple as someone unplugged the unit to vacuum or something like that and forgot to plug it back in.
If that isn't the case, then see the first line I wrote. Then you might need to reset the phone. The few wireless phones I've had, it would include either letting it run out of power or removing the battery and then a combination of buttons you had to press. But that would be mentioned in the manual.
Mar 11, 2017 | Siemens Gigaset A580 IP Cordless Phone
When I press the voicemail button to get the messages instead of going right into the voicemail messages, it just keeps ringing. The display says "Ringing ST26"
The voicemail system is not answering. Often on Toshiba systems the voicemail is a seperate PC based unit. Try locating voicemail and check for power or reboot. If this is a PC based voicemail, a common failure is the voiceboards in the PC that allow calls to be answered by the voicemail. If you detrermine that voicemail is running but just not answering, a bad voice board is the likely cause.
Jan 21, 2011 | Toshiba DKT-2020 Corded Phone
Phone rings, but once answered its not possible to hear a voice.
Similar issue - brand new phone - but incoming calls (skype or landline) would ring - and then nothing, and outgoing calls the handset would just reset.
The handset would just lose signal constantly (less than 2 meters from the base station).
The phone shipped with the latest software - but eventually I reinstalled it - no change, then de-registered the handset, powered everything down and re-registered the handset and that *seems* to have done it .....
So
1 - reflash / re-install latest software from philips website (even if the phone already has the same version)
2 - de-register handset (follow instructions)
3 - unplug base station and remove batteries from handset
4 - turn on base station, put batteries in handset
5 - re register handset (follow instructions in manual)
and that seems to do it.
Nov 18, 2007 | Philips VOIP8411B/37 IP Phone
Cell Phones Logo
52 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
