Question about Asko W6021 Front Load Washer
Door of my LG washing machine(front load) is not opeining, Pls advise how to open it, Thanks
  • 403 Answers
If there is water in the machine above a certain level, it will not allow the door to be opened.
To open the door, Open the hatch to the drain pump at the lower left front of the washing machine. If there is water in the machine and you can't put machine in drain, then you can detach the drain hose and drain the water into a container.
make sure that power is disconnected.
With the hatch open, remove the screws holding the red plastic handle in place. Pull the handle and the door will open. Put the handle back into its slot and put screws back in place.
Posted on Mar 31, 2011
  • Dwayne Hoo-Fong Mar 31, 2011
    these instructions are how to open door on asko washing machine.
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on · LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
Lg front load 3 yrs old stopped mid cycle Door was locked I finally got it opened. Suds everywhere. Now won't lite up or turn on. Checked plugs gfi breaker. Reset doing the above still not doing...
I would advise getting a washing machine mechanic from lg or check your filter at the front of the machine other wise the door mechism is damaged
Dec 10, 2014 | Washing Machines
Front door on LG front load is very hard to close
simple just spray on some WD40 if that doesnt work then the hinge its self may be broken if you call LG themselves they will advise you
Sep 13, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
Le Error on front load machine
Hello,This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged. Usually this small door is on the left side front below of your washer. Expect some water to come out when you open the door, etc. Clean out your filter and refit.....things should be fine.
Thanks
May 22, 2010 | LG WM-2277HW Front Load Washer
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
Asko W6021 Front Load Washer Logo
74 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
