Question about Canon ImageCLASS MF4370dn Laser All-in-One Printer
Hi, I have a canon dc 2128. I would like to scan on both side, pls assist.
Hi, I am using a PIXMA MX 310 and have replaced the cartridges. It says Check Ink U051 BLK COL. I have tried holding the STOP/RESET button but this has not worked (it has worked in the past). It won't...
Hello Maggie
You need to replace the cartridge with a new one original canon,not refill.If you refill the cartridge the printer not recognize it.If i have been useful pls give me a vote :)
Mar 06, 2011 | Canon PIXMA MX310 All-In-One Printer
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3725
Canon 3725 E000 Fuser problem E010 Drive E030 Counter E050 Duplex side to side problem E051 Duplex side to side problem E200 Scan problem E202 Scan return problem E204 Scan E210 Lens problem E220 Blank lamp open or lens home problem E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
on Jan 18, 2010 | Office Equipment & Supplies
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
Tip
ERROR codes Canon 3525
Canon 3525 E000 Fuser problem E000 Heat E010 Main motor, motor board, clock pulse E010 Drive E030 Counter E030 Counter E050 Duplex side to side problem E050 Duplex problem with cross alignment E051 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E202 Scan home sensor or home scan E204 Scan E204 Document sensor, scan reverse sensor or scale E210 Lens problem E210 Lens E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E400 Document feed problem E500 Sorter E620 Editor E620 Editing problem
Tip
ERROR codes Canon 3225
Canon 3225 E000 Fuser problem E010 Drive E030 Counter E050 Duplex side to side problem E051 Duplex side to side problem E200 Scan problem E202 Scan return problem E204 Scan E210 Lens problem E220 Blank lamp open or lens home problem E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
My canon ir2018 is giving the following error e007. Pls assist.
E007-0000 ABNORMALLY LOW TEMPERATURE (detected by sub thermistor)
A fixing film sensor failure has been detected.
Fixing film rotation error
C:
Fixing film sensor failure
The fixing film sensor is faulty.
R: - Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 11, 2010 | Canon iR 2016i Black and White Copier
Here is one problem with ir7200 pls help me
try replacing the lamp inverter pcb
try replacing the lamp xenon
loose contact in dc controller
check the wiring
Oct 19, 2008 | Canon imageRUNNER 7200 Copier
Tip
ERROR codes Canon 3025
Canon 3025
E000 Fuser problem
E000 Heat
E000 Fuser problem
E010 Drive
E030 Counter
E030 Counter
E200 Scan problem
E204 Scan
E210 Lens problem
E210 Lens
E220 Lens
E240 DC controller
E500 Sorter
E620 Editor
Canon ImageCLASS MF4370dn Laser All-in-One Printer Logo
108 people viewed this question
old marine
old marine
