Question about Dewalt Saws
Dw364 looks like an arc welder where the brushes are , blows breakers and electric brake doesn't work DEWALT WILL NOT ASSIST
  • 2,176 Answers
Could be a couple problems, first unplug tool and remove brushes, I would assume they are burnt or short, next while turning blade by hand look at the commutator to see if there are raised bars or extreme discoloring, if so the armature needs replaced. I would start with these 2, after installing new brushes you probably have to clean the commutator. Let me know if you need more assistance.
Posted on Mar 31, 2011
My dewalt d55153 starts runs then trips breaker can anyone point me in the right direction. Brushes. Windings?
if there is sever arcing at the brushes, it could be the armature , armature bearings or the windings
tripping a breaker is either overload ( short) or insulation failure causing an imbalance in the breaker causing it to trip
take the machine in for a proper inspection and diagnosis
Dec 29, 2016 | Dewalt Air Tools & Compressors
My Dayton arc welder model no.3z564 keeps popping the breaker it was working then all of a sudden started throwing the breaker.
take it to an accredited electrical shop that repairs welders as there is a dead short in the circuit.
Oct 29, 2014 | Welding Tools
I need to change out a motor on a Dw364. the cover will not come off.I have it all apart.
Careful study of the exploded parts diagram may help you find the secret to opening the cover. Usually (I've "been there" with other motors) it is some item blocking, such as the brush holders, a C ring, the fan... something is blocking disassembly. I hope this helps get you on the trail. If you don't have the diagram, a copy is at:
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW364&selectedType=3077
Jun 27, 2014 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
GUIDE DOES NOT LINE UP WITH BLADE EVER AFTER ADJUSTMENT NOTHING SEEMS BENT OR BROKE.
If you have removed the blade, check to make sure that you have assembled it correctly. All the spacers in the right place.
Feb 04, 2012 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
The motor is running slower and the engine begins to smoke as if it is burning up. A suggestion was to replace the brushes.
It sounds like some oil has gotten onto the armature of the motor where the brushes are. That will cause the symptoms of what is happening.
Get some Electric Motor and Brake Parts Cleaner at an auto supply house. Note: It is not flammable.
If you cannot find it. Get the Regular Brake parts cleaner.
FOLLOW THE INSTRUCTIONS BELOW.
1 Allow the saw to cool to room temperature.
2 MAKE SURE IT IS UNPLUGGED
3 Spray the cleaner it into the vent holes
4 Carefully remove the brush caps (Small Black things that look like buttons) There are two of them.
5 Spray inside where the brushes are.
6 Let it dry out for a day.
7 Re-assemble
8 Plug it in and see how it works.
If it is still running roughly after you do the above steps. Get it serviced. There is damage to the armature and brushes.
Hope this helps.
Best, Mark
Dec 31, 2010 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
Welder blowing house fuses, was alright for the past 5 years. welded has had new leads, also electric leads
Try replacing the breakers in the box if you know how. If the breakers has tripped more than 5 times then that weakens the breaker and it needs to be replaced, this is especially so if you it's 220 volt welder. There may be bus bar wear from arcing and you may have to buy a new breaker and put it in a new slot and not use the breaker that is for the welder at present. If its a stab lock breaker turn it off and remove it and get a new one at any hardware store. IF IT STILL BLOWS THE NEW BREAKER Call an electrician because you may have a lug failing on one leg, if this is the case the box could damage other appliances or kill the side your refrigerator is on or freezer then you have an emergency problem losing the food. let me know if this helped.
Nov 25, 2009 | Welding Tools
Hobart Ultra Arc 350 3-phase blows breaker in fuse panel
if you have a airgas dealer they carry hobart parts im not sure why you are blowing circut brackers unless they arenot big enough
Aug 17, 2009 | Welding Tools
Saws Logo
182 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
