Question about Element Electronics E770PD 7 in. Portable DVD Player with Screen
Get a new connecting wire to connect the two screens and a new car charger power cord
Solid yellow light on joystick controller will not light up and chair will not move. If we lightly shake the power cord several times that is located at the rear of the chair, problems corrects.
You have a faulty connection in the cord and need it checked. Disconnect battery and check the cord for the charging system for breaks in the cord wires and for a bad connection where it mounts to the transformer. If it is one unit you may need a new charger.
Aug 19, 2016 | Health & Beauty
HOW TO HOOK UP A CTEK BATTERY CHARGER TO A 2007 MASERATI QUATTROPORTE SPORT GT
Wise decision my friend. Because with all the electronic stuff that's still running without the switch on, it can destroy a good battery after a while of non-use. A very, very slow drain. Just connect the hot wire directly to a lead directly to the battery and the ground to a bolt on the frame. Place the male end of the 110 cord where you can easily access it to plug it into the extension cord and wire tie it there. Mount the charger in an area where it can get air, under the hood on a fender well but out of the way. Because these new style chargers are "floating" chargers, it will shut down when battery is fully charged and restart with a 1% drop. Always remember to disconnect the extension cord from charger before starting the car. Otherwise you'll be replacing the charger. It's safe to hard wire the unit like this, no power goes back to the charger with the one way diode that's incorporated in the unit. Have fun with your toy.
Jul 29, 2014 | Vehicle Parts & Accessories
Do i have to have the powern button on to charge my jazzy 600?
nope. The charger automatically removes power when the charger is plugged in. If it doesn't then there is a broken wire in the charger cord where it connects to the scooter.
Apr 25, 2014 | Pride New Jazzy 600 Power Wheelchair by...
Not charging
If you have power to the on-board charger, check inside the base and be sure that the wires to the amp-meter are tightly connected and all other connections are tight. If so, then you probably need a new charger. Instead of paying a few hundred bucks for an on-board from the mfgr. you can buy an off-board charger on ebay for around $50.00 that will plug into the 3-pin connector located on your joystick.
Just search ebay for electric wheelchair charger and you'll find dozens; make sure you get the one with 3-pin connector...most are like that.
Dec 05, 2009 | Jet 3 Ultra Power Chair
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Gateway screen flashes bright and dim
Usually the connection is one wire down the middle and their is another wire wrapped around it.
You can try to do a soldering job with heat shrink material around it, but if you don't know the procedure, it can damage the laptop.
Look at the charger and the amperage it needs as well as the voltage. You can actually just buy a new one as little as 80 dollars.
Aug 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
MP3 Wont charge or upload
u need a new cord for charging.u lost ur receipt so no problem u can buy it any electronic or computer market i hope.
Aug 03, 2009 | SanDisk Sansa Clip MP3 Player
Missing part
Charger does't connect to DVD player.
Connects to battery. Built your own, Radio Shack, female to male jack, power supply from anything handy or spend $2 at thrift shop, $2 multimeter (Harbor Freight, Cheapo), junk variable resistor (pot).
7.4--8 V adjust. Or, get fixed value resistor dependent on PS voltage.
Charge anything,
And power supply for DVD house current.
Jomayan1@gmail.com
Sep 14, 2008 | Mintek MDP-5860 Portable DVD Player
My Connecting cord was cut and thrown away...NEED HELP!!
Yes the red could be for power. Yellow for video and orange could be remote/ accessories power. Ground is usually the cover. If there is a way you will screw the screen to the car body, it should work.
Mar 10, 2017 | Legacy L7M 7.2 in. Car Monitor
Element Electronics E770PD 7 in. Portable DVD Player with Screen Logo
18 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
