I've just installed a HP deskjet 4580 printer...everything went well except an error light showing the black ink cartridge is not installed correctly....I've removed it and put it back in numerous times....any ideas?
  • 196 Answers
Reinstall drivers from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3944758
and what OS you have mension it that website and download fresh drivers this is sometimes due to DLL files missing
do vote if it helps
Posted on Mar 31, 2011
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
It will print everything except black and is brand
First, try another black cartridge. Second, make sure the cartridge is an original hp -- not a refilled/recycled cartridge. Third, click on START, then Printers and Faxes. Find the printer icon and right-click. Click on Properties, then on Maintenance. Check to see if the ink counter/inklevel for black is showing full. If not, reset it. Also, see if your driver is set to print Composite Black (all three colors will combine to make a simulated black when the black cartridge is empty.. If so, change that too.
Apr 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Hello,after refilling ink cartridges HP21 and HP22,I instaled them to my HP Deskjet F4180 printer.When there is only HP22-color cartridge in printer,everything works.But after installing HP 21-black...
Most times during a refill if you leave the cartridge out for any length of time the ink dries on the printhead or nozzels and wont allow the cartridge to print.
You can clean it manually with rubbing alcohol or try to use the printhead/cleaning feature built into the maintenance software installed on your computer.
Most times you will have to replace the ink cartridge.
Regards
Apr 08, 2010 | Office Equipment & Supplies
I can't get my HP DeskJet F300 series back online.I ve done everything, I ve even stopped the print spooler and started it again but the same problem still exists.And another problem that the ink cartidge...
First, the cartridges. This printer uses a 21 for Black and a 22 Tri-Color. The 58 is a Photo cartridge that replaces the 22, not the 21. Make sure that the cartridges are properly placed in the printer. The next step is the easier one. Might sound like some work, but it is the best way to correct conflicts with HP branded printers. First, uninstall the printer from the PC completely. Use the uninstall function. When that is done, re-install the printer onto the PC and test it. This should solve your problems, as long as there is not physical issues with the printer itself.
Sep 26, 2009 | HP DeskJet F380 All-In-One Printer
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
My HP printer's light blinks, but it doesn't print.
two things to consider.
1. If the blinking is fast (like more than two blinks per second) then the printer is damaged. Either the main controller board is fried or the carriage/ink controller is damaged.
2. if the blinking is slow ( 1 blink per second) this means that either of your cartridges is busted. remove the black cartridge then close the top cover. If the blinking stops, then the black ink is the culprit. If not, replace the black then remove the other cartridge. THis means that one of your cartridge needs to be replaced.
Sep 27, 2008 | HP DeskJet 3940 InkJet Photo Printer
373 people viewed this question
k24674
jasbo
jasbo
