Question about Panasonic Cameras
Pictures are in the memory of the camera itself: how can I get them?
    Brigadier General:
  • 11,967 Answers
Go into the camera menu and find "copy" for the option to copy the internal memory to a memory card.
Posted on Mar 31, 2011
There are pictures on the sim card that only appear when I import them onto my computer but arent there when I look threw my other pictures on the camera. How do i delete them off the sim card? Please...
Deleting files like pictures or videos in camera memory card usually can be done via the camera itself or via PC. As long as your PC can read the pictures, you don't have to delete them via camera, but you can delete them via PC.
If you don't want those "ghost" picture stay still in your camera memory, you can select all and copy or cut all of your pictures to your PC (to make sure that there are no more pictures in your camera memory). You can format the memory card to make it new again (or not, its up to you), then you can copy back only your wanted pictures into the camera memory and leave the "unwanted" pictures in your PC.
This method can also reduce used memory in your camera.
Hope this help and be kind to rate this answer.
(^_^)
Jan 06, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Why can I not see the pictures I have taken?
First, make sure that there is a memory card on the camera itself, the camera has a mode that will allow you to take sample shots even if you have no memory card.
If there is a memory card, make sure that you press on the Play button to be able to view the pictures you took.
Jun 16, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Cannot get pictures from my camera
If you can view the pictures on the preview of the camera itself then the pictures are safe. It is possible the photos reside in the INTERNAL camera memory rather than on the SD card. You may have to have the camera transfer them.
It is also possible that the SD card is NOT compatible with your camera.
What I would do is to procure a seperate SD card reader (they are very inexpensive) and remove the card from the camera and read it using the external interface.
NOTE: There are high density SD cards that are usually not compatible with older cameras... they are marked HD.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick.And there is nothing in the manual about how to fix it. When I turn on my camera I get an error...
Remove the memory card from the camera. Note that there is a small slide switch on one of the long edges of the card. Slide the switch to unlock or lock the card.
Apr 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Getting pictures from camera to memory card
first of all those pictures cant be stored itself
because camera has no internal memory
so those pictures need to be taken again by u after installing a new memory card in it
Jun 14, 2008 | Olympus SP-350 Digital Camera
Memory
hi there,
what you can do is transfer those pictures to a computer before deleting the pictures in the camera. whenever your take pictures, they are directly stored to the memory card. accordingly to your preferred memory storage. so if in doubt, save your pics to a computer before deleting.
hope this helps.
Jan 29, 2008 | Samsung Digimax S500 Digital Camera
Samsung s370
I'm willing to help you out on this.
Basically, there is no settings for picture storage on your camera.
Once you took pictures WITHOUT a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures WITH a memory card, all pictures are just saved on the memory card itself.
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
Polaroid Camera i634 Memory
I have the same camera and yes, you have to get a memory card for it. Your camera will only let you take 2 pics becuase it has little space by itself. I would recommend the 1 GB memory card. You can store up to 400 pictures on it and it is the cheapest. It is definately worth it. The pictures and video turn up very, very clear. Good luck with it!
Jan 04, 2008 | Polaroid Cameras
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
- Turn on camera
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Cameras Logo
22 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
