Question about Minolta X-700 35mm SLR Camera
Advance lever jam
Hi, I have a Minolta X-700 and the film advance lever is jammed or locked. I was wondering if you could help me maybe troubeshoot a little before I take it in to get checked out.
  • docmurdock88 Aug 05, 2008
    I'm sorry, I didn't realize that there was a whole section of similar problems, and now I feel a little silly. Found what I need to do (hopefully, I'm assuming that a new capacitor is the answer). Thanks anyway =)
  • autumnguy7 Jan 13, 2009
    I got this camera used, and I have the same problem with the film advance lever not advancing or jammed. I have no instruction manual for this model, and am not even sure where the battery compartment is. Can anyone help me here.
    Thanks. Ken, Disabled Veteran
  • 667 Answers
Yes, If you get metering lights in the viewfinder display that go out when you press the release fully to take a picture, it is the cap.
Posted on Aug 05, 2008
Where do you get service for a minolta x 700 35mm camera?
Try contacting Konica Minolta - if not joy, then your local friendly camera shop may be able to help.
Nov 29, 2017 | Minolta Photography
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
Advance film lever not working
If there's film in the camera it could have reached the end of the roll and you were unaware or it didn't indicate it. Try to rewind the film and use the rewind button on the bottom of the camera. Try pushing the button in anyway and advancing the wind lever. if this isn't the problem then the internal gear is jammed or broken and the camera needs service.
Jan 27, 2014 | Minolta X-700 35mm SLR Camera
The the lever on my minolta to advance the film is jammed, how do i get it unstuck?
If the advanced is locked and the mirror is down, you may only need new batteries. If the mirror is up, let me know
Dec 09, 2009 | Minolta X-700 35mm SLR Camera
Film Advance levar wont work. Milnolta x-700
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Aug 05, 2009 | Minolta X-370S 35mm SLR Camera
Film advance
It usually is the shutter not firing therefore jamming the advance. Try www.flcamerarepair.com They do not charge for ests.
Jun 28, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Jammed film advance lever
if the lever feels soft then you might haven't moved it till the end so try to push it untill u hear a tick if not then it's the capacitor
Feb 18, 2008 | Minolta X-700 35mm SLR Camera
Film advance lever
No problem.
Most film cameras can do that, for quick advancement.
atdlee@netzero.com
Dec 21, 2007 | Minolta X-700 35mm SLR Camera
Mamiya RB67 ProS wont trigger or advance
Start by making sure the dark slide is removed, the camera will not fire with it in place. The next step is to check the rotating back to make sure it is locked in either the vertical or horizontal position. Without film in the magazine, the multi-exp lever on the back must be set to show the red dot under the advance lever. You can check the camera without the back by removing the rotating back using the latch on the bottom of the camera
Nov 25, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Minolta X-700 35mm SLR Camera Logo
1,805 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
