Question about Cameras
When the pop up flash is up no matter what the light situation the flash will not flash.
  • fgerald Mar 31, 2011
    The camera is a Nikon N4004 AF purchased in January of 1989. I have to pop up the flash manually. It does not have a menu on the camera, Type of camera: Integral-motor 35mm single leans with built-in TTL flash 24mm x 36mm (standard 35mm film format)
    Did you receive my second comment about model of camera? If not I cans end again.
    President:
  • 2,761 Answers
Kind of difficult to answer without a make & model, but the flash should pop up every time you power the camera ON. If you search through the camera's menu you'll find a flash option that let's you select when the flash will work. You likely have it switched OFF.
Posted on Mar 31, 2011
  • Cameras Master
  • 17,970 Answers
This problem is due to a switch being stuck even after the speedlite has been removed from the hot shoe; just try lift the flap a bit and you should be good to go.
I find this problem in a Canon 7D, seems the micro switch underneath the right rail of the hot shoe, sticks. After Canon repaired the switch has not stuck again.
Also, could take a look here: forums/read.asp?forum=1019&message=36794299
Hope helps.
  • ZJ Limited
    ZJ Limited Apr 10, 2011
    There is really something wrong as the flash no longer fires in any of your settings. The camera still thinks the flash still fires and thats why it lessens the exposure to accomodate the added light, but since it no longer works, your images will become heavily underexposed in auto and "P" settings.
  • fgerald Apr 11, 2011
    I tried to get across to Fixya that my problem was with a FILM camera. After sending more details of model and other information about my N4004 Nikon FILM camera, they continued to send me solutions for a DIGITAL camera. No help at all for my FILM. FILM, FILM CAMERA!!! The pop up flash still does not work!
    Fred Gerald
Microwave made a loud popping sound and had a bright flash of light. Has done this twice.
That is most likely caused by a failing wave guide cover. It is situated in the cavity and protects the magnetron.
Most dealers keep or can easily get them.
Hope that helps.
Mar 04, 2011 | Sharp R-1610 Microwave Oven
We have a Canon rebel XT EOS the flash pops up no matter what the
Frustrating I am sure. I had the same problem on my first XTi. I cannot remember what the settings were, but I think I was set for portrait and had flash set as the white balance default source. Therefore the camera always popped up the flash assuming that I wanted or needed fill flash.
Change you white balance to sun/shade/tungston etc as is appropriate, choose a faster ISO speed in lower light levels and try using the P or Tv mode and use a shutter speed that generates a middle range aperature for your particular lens.
Jan 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
How can I disable the multi flash on the Olympus e-510 in auto mode
I'm not certain what you mean by "multi flash". I'll give you two answers. 1.) If you are attempting to take a picture under low light levels, the rapid flashing is the camera adding light to the scene for the autofocus to work. You may have to manually focus in these situations if you don't want the rapid flashing. 2.) The autoflash can be disabled with the flash button on top of the camera. Pressing it once will open the pop up flash. Pressing it a second time will bring up a menu on the screen. Highlight the lightening bolt with the line through it and press 'OK". Auto flash can also be disabled by using one of the scene modes such as low light, candlelight, night scene or fireworks.
Oct 13, 2009 | Olympus E-510 Digital Camera
Have a nikon d60 and the flash will not go off even when in a dark situation. Pops up but no flash?
if it pops up then the sensor is working and the mechanical parts are working,
Next is manual force flash test, if is manually flashes, the bulb is good else replace the bulb.
Sep 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Should the flash pop up on its own?
Yes, the built-in auto flash automatically pops up in dimly lit or back lit situations.
Apr 20, 2009 | Pentax *istDL2 Digital Camera
Indoor picture too dark with flash
Hey Jewdeit,
The built in flash on the K100D has guide # of 52 at iso 200 which does fine for close-up photography and as fill flash outdoors, but is not a powerful enough flash for shooting far away subjects indoors. What you probably should do is purchase an external shoe mounted flash such as the AF540FGZ which has a much higher guide number of 148 at iso 100. When shooting with flash if you are using aperture priority or full manual you can also try opening the aperture to let in more light that the flash put out, but doing this might over expose anything in the foreground.
Sincerely,
Allan
Go Ahead. Use Us.
May 06, 2008 | Pentax K100D Digital Camera
Flash
This is the AF Assist feature. If you don't have a hot-shoe flash mounted, but you do have the pop-up flash raised, the camera will strobe the pop-up flash in low-light situations to provide illumination for the auto-focus to work. You can disable it by turning off the AF ILLUMINATOR option in the "Wrench 1" settings menu.
Mar 09, 2008 | Olympus EVOLT E-500 Digital Camera
Low light situation
Where the Panasonic FZ-20 does very well, is with conditions where you need a long zoom under low light. Most lenses will lose light as they are zoomed out. The Leica lens in the FZ-20 does not lose light when zoomed. No matter which camera you are using, you will have to use the manual controls for the best results. So learning about exposure and how to use it, is necessary.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
