My maddog MD- 18XTFI burner just stop working. It does not read any disk and I cant even burn anything. All I had done is up grade a hard drive. What could be wrong with it?
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 31, 2011
Dont read cds can read before
In most cases the cd-rw's after a time there stop reading cd's or dvd's . u can't do anything about that issue because it's from laser that had benn moved a mm grade of accuracy . have a nice day
Jan 02, 2011 | HP Disk drive - CD-RW / DVD-ROM combo -...
How doyo record a dvd on te md dog dvd burner
hey you need a software, nero, roxio, etc. something like that, or your maddog have its own software together with your dvd drive. you just have to open the application.
Apr 01, 2010 | Mad Dog Multimedia MegaSTOR...
I have a mad dog usb externall dvd burner model md-16xdvd9a4 i had in the closet for awhile since i had an internal dvd burner, recently my internal failed so i pulled my maddog usb out to use. it wont...
First do windows update until everything is fully updated, pay careful attention to any hardware update that is needed in the left column and if that does not help go double click on MY COMPUTER select the drive( D) then right click, go to PROPERTIES then RECORDING set or change your defaults.
Hope this helps.
Dec 19, 2009 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Unable to write to NEXXTECH DVD-Rs in my MadDog MD-16xDVD9A2 driv
Try different medias. If it does burn then your media is incompatible. If it does not, check your dvddrive software and hardware. You could use other burning software to check if it is software. Check the status of your hardware in device manager and bios.
Clean its lens using lens cleaner. You can uninstalled and reinstall it.Having all and still it doesn't write, then it is due for replacement.
May 31, 2009 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Will not read disks
Is this an older drive? Possible that the drive is dying. I had this happen to me once. I ended up buying a new cd/dvd burner. The laser works different when reading verse burning, so it is possible that it is dead, but still working just enough to burn.
Apr 20, 2009 | Computers & Internet
Will not burn anything, or read anything
try this
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Mar 03, 2008 | Computers & Internet
Annoying Problem with MD-16XDVD9A4
This is a now issue with XP when you install a DVD/CD-it doesn't always happen but when it does there is nothing that can be done about it-I went as high as tier 3 support at MS and tried regediting, mapping, even a complete reinstall-nothing helped-untill I bought a cheep CD RW and installed it as anotuerh dirve. Then I had a DVD RW, and a CD RW. Problem solved
Nov 05, 2007 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
